Page 1 of 2 12 LastLast
Results 1 to 20 of 31
Thread: Bleach vs Easy Pour bleach
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    I typically buy bleach from Wal-Mart. They recently changed their labels so I have been paying close attention to what I buy and what gets brought home by others in the house. I noticed today that I added "Easy Pour" bleach, a change in the bottle I had not noticed. All my other bottles say "Bleach" bleach. The bottles are designed the same and pour the same. The Easy Pour however does not list ingredients nor does it say splashless. However, I filled the empty bottle with water and it bubbled like crazy. Like it had soap in it. Does anyone know if there is indeed a difference in the two?
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    38,295
    Re: Bleach vs Easy Pour bleach
    Multiple threads on this in the last few weeks. Including reports of it causing foaming, so there appears to be a difference.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I think I also saw somebody said there's no percentage of chlorine listed on the jug. If there's no chlorine percent listed, don't buy it. That goes for anywhere. 😎
    Jeff
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Thanks. I searched but honestly with no keywords other than bleach and easy pour I guess I missed them. I will have to change then. I don't care for the soapiness of it.
    Mar 2007
    San Rafael, CA USA
    12,082
    As noted in the Pool School Definitions and Abbreviations and in countless threads on this forum:
    Bleach
    See sodium hypochlorite, below, because that is what bleach is. It comes in 8.25% strength as Concentrated bleach, 6% strength as Ultra bleach, 5.25% strength as regular bleach, and sometimes as 3% strength for some of the 'cheapie' bargain bleaches. You want to use plain, unscented bleach for your pool, not the scented, no splash, outdoor, or thickened kinds! One gallon will raise 10,000 gallons of water approximately the percentage of the bleach in FC (i.e, one gallon of 6% ultra bleach will raise 10,000 gallons approx. 6 ppm FC).
    Splash-less bleach has thickeners that prevent it from splashing and such thickeners foam up like soap when in water.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    OMG Glock did you already put that in your pool
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Jul 2014
    Peoria, IL
    389
    Yep, WallyWorld got ya. I go to Walmart about once a year, but I have how they constantly change their labels. I usually use LC, but if I need bleach I hit up Sams Club for the Clorox 3 pack.
    Did it foam up on ya??
    If so I do not see why you could not use the foam remover stuff for hot tubs.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Mar 2007
    San Rafael, CA USA
    12,082
    It's easiest just to scoop out the foam from the surface of the water. Eventually it will get removed, but it won't break down from chlorine (after all, it's in concentrated chlorine product).
    Jul 2014
    Cedar Park, TX
    114
    I ran across this stuff as well. Funny after 60 or so bottles used in my conversion I was careful to get the standard Walmart bleach. The last time I went to the store one of the Easy Pours snuck in. Last night I was adding and was in a rush. Thought the bleach poured differently. Today I noticed the label. Well the pool has about 19oz in it. Nothing to worry about I am sure. I easy poured the rest of the **** down the drain.
    12600 gallons, 24 foot round above ground
    Hayward Sand filter, Hayward Powerflo 1.5 hp Single Speed pump
    Sep 2013
    810
    Ugh!!!!!!!!!!
    Nov 2014
    5
    The easy pour has soap and the bleach is only chlorine but; we are in pool forum and I would not recommend this because pool chlorine is double the straight and les TDS. In other words you are making your pool water two times older then the rest of the people, at the end you will need way more chemicals. Take a sample of water to pool store and ask the your levels and also ask them the recommended levels on your area.
    Nov 2014
    United Kingdom
    220
    Here in the UK we buy Sodium Hypochlorite 14/15% in twenty litre drums for about 20
    Is this not available in the USA as it is more concentrated than ordinary bleach
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Quote Originally Posted by Juan Sandoval View Post
    Sent from my iPad using Tapatalk
    Here at Trouble Free Pool they recommend you learn to test your own water with the recommended levels in Pool School.
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    ?? I'm slow sometimes, Can you explain what you mean here?
    As PAGirl stated, TFP strongly supports that the Pool owner do their own testing with A proper test kit and follow guidelines in Pool School & PoolMath
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    38,295
    I would disregard what Juan said. It does not follow the TFP teachings and sounds like old pool store rhetoric.
    Sep 2013
    810
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    I think what he is getting at is liquid chlorine is twice as strong so you only use and therefore dissolve half the chemicals.
    Not sure about the twice as old part but have read some of his posts before that seemed spot on.
    Maybe we would all be better off if nobody shopped at Walmart at all. ( not looking for a big debate here. If you shop there you probably find it to be a guilty pleasure.)
    I'd personally rather support a mom and pop type pool store for what I already know I need than a place like Leslie's and would never set foot in a walmart.
    That's just me though.
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Quote Originally Posted by denniswiseman View Post
    Not commonly, no. But I can get 12.5% bleach in refillable gallon jugs, 4 to a case, easily, and about half what you're paying.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Richard, do those 4 gallons come in a yellow tote? If so I think you have the same chlorine producer that I do here in Texas (HASA).
    A note on the easy pour/spash-less, it's will foam up in a HE washing machine too.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
  20. Back To Top    #20
    Mar 2007
    San Rafael, CA USA
    12,082
    This is simply not true. The amount of salt on a per FC basis is the same for 6% or 8.25% bleach as it is for 10% or 12.5% chlorinating liquid. For every 10 ppm Free Chlorine (FC) added by bleach or chlorinating liquid, it also increases sodium chloride salt by 17 ppm after accounting for chlorine usage/consumption.
    The only advantage of chlorinating liquid over bleach is that there is less weight to carry. Of course, prices vary and the amount of excess lye can also vary, but the salt level does not because the salt comes from the chlor-alkali process and that process is not different between production of bleach vs. chlorinating liquid (see this post).
