Thread: what's this on the bottom of my pool
    hi all, please have a look at the link showing the bottom of my pool. My pool water is balanced, new filter with new sand. I'm not sure what this is, it feels a little grainy when i touch it, it disappears if i spread it. Vacuuming it doesn't help for long. I don't think it's algae, i've super chlorinated the pool thinking it was, comes back.
    http://tinypic.com/r/eti5n9/8
    thankyou.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Re: what's this on the bottom of my pool
    What are you using to test the water and what are your latest test results?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    hi, please see link for latest results
    http://tinypic.com/r/11kcc38/8
    Could it be mustard? My previous super chlorination was to throw 20 litres of it in?
    Sep 2013
    810
    Are those pool store test results? You should get yourself a good test kit and do your testing yourself. Those pool store tests are frequently inaccurate. We can't advise you on what to add without knowing the source and strength of your chlorine, but I can definitely tell you that your FC is low based on your CYA. If you do in fact have algae you need to follow the SLAM instructions step by step, not just throw a huge quantity of chlorine in the pool one time and hope for the best.
    zethacat, thanks for clarifying that for me, I will read the slam instructions.
