Thread: in line liquod chlorinator
    Aug 2014
    Lake Jackson,Tx. 45 miles south of Houston
    44
    Whats a good in line liquod chlorinator? Need one before the spring.
    13,500 gallon pool without a spa Inground
    Pool built by previous owner in 1995 but replasterd in 2008
    DE filter (pentair FNS plus 48,Challenger 3/4 hp pump,In line chlorinator (switching to liquid bleach)
    Using TF-100 pool testing kit
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: in line liquod chlorinator
    You have two main options. The first is something like the Hasa Liquidator which uses the pressure difference across the filter and pump to inject liquid chlorine. The second is a Peristaltic metering pump which injects liquid chlorine from a tank into the return line. Search for "Stenner" on the forum to get more information.
    Aug 2014
    44
    Thanks I will do that.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,205
    What you really don't want is an in line tab chlorinator.
    I went with a Stenner pump, you can see it HERE.
    The downside to both the liquidator and stenner is that you are still carrying bottles of bleach/chlorine. The only way to eliminate that is to go with a salt water chlorine generator. Now, they come with their own set of issues so take the winter and research all of the options. Don't take my word or the word of anyone anyone else, do your research and see what works for your situation. But please, don';t stop by the local pool store and ask what they think.
    Support the site
