Thread: FAS - DPD Test Kit
    Nov 2014
    Palm Desert, CA
    99
    FAS - DPD Test Kit
    Does anyone have an item number for a FAS -DPD Test Kit? I already bought the Leslies Kit 18-576 which seems to have all the other tests I need except for this one. Thank you!
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: FAS - DPD Test Kit
    You can get the FAS/DPD Chlorine & CC's test from TFTestKits or you can get the K-1515A from Taylor Technologies (or someone who can order from Taylor). The TFTestKits uses Taylor reagents, but is more economical since it's less expensive and has more reagent so you can do more tests (see Test Kits Compared).
