Thread: Desired set temp past max on Minimax 400
    Nov 2014
    Houston, Tx
    1
    My heater will only reach about 96 degrees inlet temp with either temp control knob set to max. If I turn the knob harder so I am past the end of the pot I can get it to relight but then it is in a non linear zone and it goes up to about 110 before shutting off. I have tried fiddling with the two pots on the back of the board which I have assumed are for trim but they have no detectable effect. How do I get the desired set point of 103 back into the range of the controls? Thoughts?
    Thanks!
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Re: Desired set temp past max on Minimax 400
    You're probably going to need to replace the board.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
