Thread: Increasing CH without increasing chlorine?
    Jan 2014
    Perth, Australia
    31
    Dear forum members,
    I have tested by pool water and my CH needs to be raised. It is currently measuring ~130ppm and I would like it around ~275ppm.
    Checking pool math it seems I need to add something like 5kg of Calcium Chloride. The problem is (if I understand this right) that this will also raise my chlorine levels, quite a lot!
    What's the best way to do it then, turnoff my SWG and add the calcium over a few day in many batches? Or is there some other way?
    Thanks!
    IG Fiberglass Pool - Sep/2013
    Pool capacity: 27,700 liter / 7,317 gallons
    Emaux V Series Sand Filters - Model: V700B; Size: 28"; Flow Rate: 89 gal/min
    Viron eVo P320 Pump; Flow rate (low/med/high): 32 gal/min, 56 gal/min, 66 gal/min
    Viron V18 pH Salt Chlorinator + RolaChem RP9 Automatic pH Controller
    Re: Increasing CH without increasing chlorine?
    Calcium chloride will not raise chlorine levels at all. Calcium hypochlorite does raise chlorine levels along with calcium levels, but that is a different chemical. As long as you use calcium chloride you will be fine.
