Thread: Hayward H400IDPL Heater Problem. Flame lasts only few seconds.
    Apr 2014
    USA
    25
    Iím having a problem with a Hayward H400IDPL Heater.
    The flames come on but then go away after only a few seconds.
    The heater will keep trying and cycle like this without giving an error code.
    The exhaust will be hot for only maybe 3 seconds.
    It seems to me like a problem with the flame sensor. The heater thinks thereís no flame and itís filling up with gas.
    Any ideas?
    Thanks
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Hayward H400IDPL Heater Problem. Flame lasts only few seconds.
    If it were a flame sensor failure, the unit should post a IF on the display.
    Is this a natural or propane gas unit? If propane, are you sure you have propane in the tank?
    Take the front panel off and inspect the insides. Make sure that the burners are in place and there are no other obvious issues like chewed/burned wires. I would also check to make sure there is no obstruction in the burners or the orifices.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Hi, the heater after three tries should show a error code. If the heater is lighting than shutting down and continues to do this without an error code there could be something going on with the exchanger, firewalls or burners. I strongly recommend that you have a heater technician look at the heater.
    John the Hayward tech
    haywardtech@gmail.com
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    If the unit is sooted up, it can also cause this issue. Also a bad control board could cause it as well. Unless you really know what to look for, it can drive you crazy.
    Paul
