Results 1 to 10 of 10
Thread: Question about start-up and borates
    Oct 2014
    Corona Ca
    10
    I would like to add borates to my pool. Should I do this ASAP or wait till the pool has been filled for a few months? I am currently towards the end of a build now (waiting on decking and plaster). I have already ordered my test kit tf-100 and Iím really anxious to put all the info I have gathered off this site to work.
    16x32 20,000 gal
    Above Ground Plaster Pool
    Pentair Cartarige Clean & Clear Plus 420
    Pentair Intelliflo Variable Speed Pump
    TF-100 test Kit
    Re: Question about start-up and borates
    Welcome to TFP!
    I recommend waiting to add borates until you have all of your other levels where you want them. If everything goes well that will probably only be a couple of days after you fill the pool.
    Oct 2014
    Corona Ca
    10
    ok thanks Jason.
    16x32 20,000 gal
    TF-100 test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome Mike!
    If I may kindly suggest, post up a full set of numbers once you get comfortable that you have some accurate numbers from your new kit.
    Before you decide to add Borates that is.
    Essential Links:
    Oct 2014
    Corona Ca
    10
    Will do
    16x32 20,000 gal
    TF-100 test Kit
    Oct 2014
    Corona Ca
    10
    I found a place on line that sells boric acid. it looks to be less than 100bucks delivered. It looks to be cheaper than 17 boxes of borax and 5 gallons of muriatic acid. My question is, am I looking at the wrong Boric acid? Is there more than one kind? Is my math wrong? I thought the whole point of using the borax/ muriatic acid was to save money.
    PS they are pouring concrete in the morning I will have to post pics soon.
    16x32 20,000 gal
    TF-100 test Kit
    Jun 2013
    East TN
    309
    Boric acid will probably be 100% or 99% pure. If that is so then you have the right one. Anything can be cheaper at the right price. That last time I looked around Dudadiesel.com had the cheapest price. Not sure about the shipping cost though.
    http://www.dudadiesel.com/search.php?query=boric
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    If you shop around carefully then Borax and muriatic acid is almost always a little less expensive. But boric acid is close in cost, and much easier to handle. The largest advantage of using Borax and acid is that it is available locally, while nearly everywhere you need to mail order boric acid.
    Boric acid that is "technical grade" or "food grade" is fine. If it doesn't have either of those grade labels, look for 99+% pure.
    Oct 2014
    Corona Ca
    10
    dudadiesel.com is where I found it. I would assume follow the same proceduer to add borates with boric acid?
    16x32 20,000 gal
    TF-100 test Kit
    Boric acid is much easier to use than borax and muriatic acid. You can simply distribute boric acid across the surface of the pool all in one dose, and then leave the pump running for an hour.
    Granular boric acid is best, powdered tends to blow around annoyingly.
