Forgot to discuss the following. Since the Max-Flo SP2302VS would produce a comparable GPM flow rate at max speed 3000 RPM as my current pump, then I in essence may have the same suction/risk at the flat main drain that I have presently, right? While I had originally planned to go with the Ecostar, and I was concerned about its power and suction/risk at my flat main drain, I had planned on replacing my main drain cover with an anti-entrapment type. But, I would assume, this risk would be significantly reduced by replacing with the Max-Flo. Correct? Thus, while I would still plan on doing it eventually, there would be less urgency to replace the main drain cover if I go with the Max-Flo.
Also, on pg. 9 of the Hayward Max-Flo SP2302VS manual in section 4.3 Pipe Sizing Chart (
http://www.hayward-pool.com/pdf/manuals/maxflo-vs-IS2302VSP.pdf), it states that if 2" pipe is used, the minimum straight pipe length for the suction side is 10." Should this be concern if I don't have that minimum length? Would that affect anything? Presently, I have about 4" from the point it makes a 90 degree turn to go into my pump. I really don't have a lot of room for a 10" pipe. Here's a pic:
Edit:
I just got off the phone w/ Rick, in tech support, at Hayward. I was asking him about the suction side pipe length and something I saw in the manual about a Max-Flo SP2302VSPND model. He stated that the minimum pipe length for the suction side pipe was to reduce the water turbulence coming off the 90 degree bend and improve pumping flow. I asked if this could affect the warranty if I go ahead and keep the short pipe length as this point b/c I don't really have the space for a 10" run, and he stated that it could affect the warranty if the pump/motor fails and it is deemed to be related to turbulent water/increased air flow into the pump d/t this short pipe length.
The other issue was reading something about a Max-Flo SP2302VSPND model. He said this was the No Display model. It relates to the fact that if I went with one of the approved automation controllers for the Max-Flo (Pro Logic, E-Command 4, OnCommand) that the Max-Flo SP2302VSPND model would be the one that could be fully controlled. The No Display refers to the user interface module not being needed on the pump. He stated that the Max-Flo SP2302VSP model (the one with the display/user interface module) could still work with the automation controller, but that the pump operations/programming would still take place through the user interface module on the pump, and the automatic controller would be used for any other features i.e. heater, solar. Now when I look at page 13 of the manual it clearly shows in the 5.2 heading "Hayward Control Wiring (SP2302VSPND only)."
These 2 paragraphs tell me a few things. If the pump fails or there is a warranty issue, it will be out of my hands and hopefully not denied over one thing or another not being up to their requirements. They could always find something it seems. So, I will just have to hope for the best. Secondly, the ND model thing is a bummer if I ever wanted to go with an automatic controller and not have to deal with touching the pump and keep everything centralized. Looks like that option is out b/c I would have to replace the pump yet again to that SP2302VSPND model.
