- May 3, 2007
- 16,879
- Plaster
- Hayward Aqua Rite (T-15)
A vacuum release valve is usually plumbed near the solar panels and it is a one way valve that allows air into the plumbing but prevents water from leaving. The purpose of a VRV to allow the panels to self drain so they do not contain water when the pump turns off. This prevents freeze damage in areas like ours where we normally do not close the pool but still has the potential of freezing.
Correct.And my interpretation of your last couple posts is that if I do not have a solar control that connects with my pump, then I just set an appropriate RPM during the summer/solar season that would activate the solar. And, on those days that it is overcast/not warm enough to run the solar, it will still run at that RPM just because that is the programmed time. But even if this new motor or variable speed pump runs at a higher RPM even if solar is not on, it will still be more efficient than my single speed.
