First, I thank you Mark, as I always have, for all the assistance you have given me with this matter. Second, I should not be made to feel that I need to apologize for having a thread that is lengthy or a topic/matter that is exhausting. I may suffer from analysis paralysis, but in order to make an informed decision, I owe it to myself to explore all concerns related to a pump/motor replacement. Never did I think that this topic would have led to a thread of this length. What I take from this is that a pump/motor replacement is a very involved decision that affects/could affect many different pool systems (i.e. main drain, solar, circulation, etc.).
I have perused the thread and do see that you are quite certain that the MaxFlo would work. I don't question that anymore. My last thread was simply to discuss new thoughts r/t to possible size differences of underground plumbing and any negative affect it would render on the pump/flow rate. It sounds as though it would only have a small affect on the flow. But, that is wherein my concern lies.
I did some investigating in my owner's file that has been past from owner to owner. I found the blueprint construction data on the pool. I have included a pic. I don't understand what it shows in the plumbing section. It appears that I do have 2" and 1.5" plumbing both on the return and suction side. For instance, on the return side, it shows 8'-90' of 2"-1.5". On the suction side, it shows 10'-19' of 2"-1.5". Whatever this means, it looks like I have some 2" and 1.5" plumbing. One comforting thing though is in the equipment section it shows that the original pump HP was 1.5. So, the 1.5 HP pump must have worked at one point over this pool's history. The pool was built in the '70s, but I don't think they had solar installed until some unknown later date.
Prior to post #49, I gave you the specs. on my system. And, in post #49, you stated:
Without solar, your old pump would produce around 75 GPM and the MaxFlo (3000 RPM) would produce about 76 GPM. With solar and assuming 18 PSI, which seems a little high, the flow rate for your old pump would be about 59 GPM and the MaxFlo would be 55 GPM.
In post #53, you stated:
But because your panels are 288 sq-ft, you technically only need about 30 GPM for the panels. The reason the pressure rise is so high might be because you are forcing much more water through the panels than is necessary. With a VS, you will be able to set the flow rate so that there is only 30-40 GPM going through the panels. For the MaxFlo, this would be 1800-2100 RPM. But this might not be enough flow rate for priming so some trial and error might be necessary.
If the 1.5" plumbing would affect things, could it be drastic enough to reduce the flow of the MaxFlo, at 3000 RPM, to less than 30-40 GPM, which sounds to be the minimum for operating solar? Given this new information, how much lower than 55 GPM would the MaxFlo pump at with solar operating?
