Thread: Reduced Temperature and Bromine
    Nov 2014
    Silverthorne/CO
    2
    If I want to turn down the temperature if my hot tub isn't going to be used for a few days, how low can I go? Ive heard that below 85F the bromine no longer works. If I only use it once a week, do I have to do anything different with using the bromine tablets if I want to turn it down between uses?
    Re: Reduced Temperature and Bromine
    Bromine is just fine at cooler temperatures. If you are using bromine tablets, they will dissolve more slowly at the lower temperatures, so you may need to use two or three at a time, but they will last longer so it won't use any more in total than you were using before.
    Nov 2014
    Silverthorne/CO
    2
    Our tablets are in a floaty. So dropping the temperature to 70F and leaving it for a couple weeks shouldn't be an issue?
    Not a problem. You essentially treat it as normal.
