Thread: Freeze protection ?
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Freeze protection ?
    So we're going to see some modest freezes starting tonight for a few days .
    I'm not worried about main pump & filter (I can just let that run I guess)
    BUT what about the separate pump & pipes I have for the waterfall ?
    I don't really want to run the waterfall pump so just open the filter basket lid to let air in or actually drain the pump ???
    THANKS
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Freeze protection ?
    If you can drain the waterfall and pump, then it should be fine. The water in the pipe underground should be fine.
    Also, if you would prefer not to run the pumps, here are some alternatives I posted on another thread:
    I am not a big fan of using freeze protection because it gives you a false sense of security and based upon many posts on this site, tends to fail in one way or another especially when the power fails. In addition, it turns on far too soon and wastes energy. It is easy to use but not fool proof.
    We haven't reached freezing temps yet but we usually get down to low 20s and usually not for more than about 8 hours. I haven't used freeze protection now for about 8 winters without incident. I know Texas has a bit more extreme temperatures but if temps should get below 25F or below freezing for more than 8 hours, there are alternatives to freeze protection:
    1) Cover the equipment pad with a tarp and put a 60 watt light bulb underneath the tarp. This is more than enough to prevent anything under the tarp from freezing (unless you are way up north). But this is still susceptible to power outages.
    2) For really cold weather, drain the equipment pad. This is a fool proof method and is not affected by power outages. But it is a bit of a hassle so I would reserve that for very severe weather.
    Mark
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Quote Originally Posted by mas985 View Post
    Thanks
