Page 1 of 2 12 LastLast
Results 1 to 20 of 30
Thread: Covered equipment
    Jul 2013
    Waxahachie, Tx.
    446
    Covered equipment
    I made a removable frame from pvc that can be easily slipped over the pump and filter. Then wrapped a tarp over it. If the temperature gets really low I will hang a cord with a 100w bulb under the tarp. alsp have a freeze protection feature built into the timer. I set it for 34. Last nite temps in N Tex reached 32 in places. System worked as designed. Got this morning and pump was running.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: Covered equipment
    my only suggestion is to make sure that the enclosure doesn't protect the freeze protection temp switch/thermostat.
    I say that sounds like a great idea. pics?
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Jul 2013
    Waxahachie, Tx.
    446
    Funny u should mention that. I just came in from checking that.
    Jul 2013
    Waxahachie, Tx.
    446
    Picture is too big will have edit it
    It exceeds my quota
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Quote Originally Posted by rmturner54 View Post
    It exceeds my quota
    With pics, I'd suggest using a program/service like photobucket to upload to most forums. It's free and doesn't use up forum resources.
    great minds think alike. lol
    Jul 2013
    Waxahachie, Tx.
    446
    Photo bucket sounds like a great idea....i am all over it
    Jul 2013
    Waxahachie, Tx.
    446
    Frame with tarp.
    Jul 2013
    Waxahachie, Tx.
    446
    Got picture om photobucket. Posted it with new topic. How do i get it in this post
    Jul 2013
    Waxahachie, Tx.
    446
    http://i1379.photobucket.com/albums/...pszn7haqek.jpg
    Try this, The timer witht he freez protection is on the left.
    38,303
    You should have just entered the Photobucket link in a reply in this thread. I now moved it here.
    Jul 2013
    Waxahachie, Tx.
    446
    I figured it out after the fact
    Sep 2013
    Nashville, TN
    382
    Covered equipment
    That's a good idea, I built a wooden enclosure for year round coverage to block view of the equipment and pushed foam panels in behind to block wind and retain any heat the pump may generate.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    38,303
    You need to make sure the motor does not overheat in the summer ... should have good air flow.
    Jul 2013
    Waxahachie, Tx.
    446
    This is just for winter until i have time think about how to proceed
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    That looks awesome but I think it's overkill for Waxahachie BTW can you build me one too
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Jul 2013
    Waxahachie, Tx.
    446
    Quote Originally Posted by Sseaman View Post
    Looks good. I plan on a permanent cover after the winter. I will modify my PVC cover
    Quote Originally Posted by zethacat View Post
    Are you sure your replying to the right post. Mine is the tarp and PCV .Waxahachie just had freezing weather this last weekend.
    I had to put a 1 x 2 on edge under the tarp to prevent water sag.
    Sep 2013
    810
    Yes, I live in Grand Prairie right by Joe Pool Lake. I've got pretty much the same weather as you. Check out this thread:
    http://www.troublefreepool.com/threa...eze-Protection
    mas985's Avatar
    Pleasanton, CA
    11,737
    If the enclosure covers all the above ground pipe (ie. no AG water features), then I would put the air temperature sensor underneath the tarp because there is really no reason to run the pump unless the above ground plumbing is below freezing temperature.
    Mark
    Sep 2013
    810
    And even then, I imagine it would take some time to bring the water inside that plumbing down to a freezing temperature.
  20. Back To Top    #20
    Jul 2013
    Waxahachie, Tx.
    446
    Sensor is outside tarp. i understand the thinking. My pump is very cheap to operate. Iam leaving my pool open all year. So monitoring the true outside temperature is more important to me.
