Thread: Chlorine / CYA Chart
    justinjla's Avatar
    Nov 2014
    Sachse/Texas
    15
    My CYA and FC is currently 40 and 5. What does the shock FC mean in the chart? Sorry, newb here.
    17,000 gallon
    In ground tahoe blue plaster
    DE filter (DEV60)
    Jandy variable speed & jandy booster pump
    Jandy pro series heater
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Shock is the FC level that will kill algae. If you have algae that's the FC level that needs to be maintained to kill the algae bloom.
    Here is the process you'll have to use if you have an algae bloom to kill it off.
    SLAM Process 😎
    Jeff
    justinjla's Avatar
    Nov 2014
    Sachse/Texas
    15
    Re: Chlorine / CYA Chart
    Great, thanks!
    17,000 gallon
    DE filter (DEV60)
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    If you haven't checked out "pool school" on the upper right corner of the screen (your right, not the screens). Check it out. some absolutely great info in there.
    here's the getting started link
    http://www.troublefreepool.com/conte...etting-started
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    If your CYA is 40 they you are correct in trying to maintain the FC at 5 and you need to never let it drop below 3 to maintain clean and clear water.
    Solar Blanket, Well Water, Borax Added. 68
