Thread: Water a greenish color
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Acrylic spa. Water has a greenish tint to it. pH is at 7.4, Br around 2. The last time I filled up the spa I did NOT use a metal sequestrant. Is that my culprit? I'm in phoenix and we have "hard water" with calcium always being a problem. If that is the problem, am I able to add that even now to my month old water? Normally instructions are to add while filling up but I'm assuming I can add any time.
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Water a greenish color
    Yes, you can add sequesterant at any time. If its metals it should respond pretty well. SequaSol, Jack's, GLB - those are good brands.
    38,242
    See the article in Pool School for the recommended metal sequestrants: http://www.troublefreepool.com/conte...d-metal-stains
    If metals are the problem, the sequextrants should clear up the water.
