Thread: Raypak rp2100 blew out it's unitherm governor last night
    Jun 2013
    Dallas, TX
    105
    We had our first freeze in Dallas last night. Woke up this morning to water pouring out of the unitherm governor port on the rp2100 while the system was cycling for freeze guard. I found the plug and the thermostat (which looks super rusted and gunked up) on the ground. Turned everything off and went into work.
    Some questions:
    • Why did the UG blow out? (Freeze guard was on, and I had the pool running all night.)
    • Is the fix simple as replacing the UG and the cap?
    Other info:
    I haven't used this heater in a couple years. It worked when we moved into the house, but a year later stopped heating. Just never got around to having it fixed. When turned on, you can hear the ignition firing and smell gas, but never seems to light. Are these problems related?
    Thanks!
    35k gal, sand, IG, diamond brite, Hayward Goldline T-CELL-15 Turbo SWG, Aquarite, Compool Lx3600
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    Re: Raypak rp2100 blew out it's unitherm governor last night
    Wow a freeze already in TX. Yes replace both parts. Why did it happen? Well water couldn't flow correctly because of the gunked up unitherm.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2013
    Dallas, TX
    105
    Update: I had my pool guy come out. The thermostat seized up, causing pressure to build up and it to blow out.
    Worse news is that my heater is shot. Not from this, but the bottom fins are all rusted out. Went ahead and just bypassed the heater to get it running. The threads were stripped, so we couldn't just cap it.
    Total to replace and install the heater would be $2400. I can live without a spa in the winter for that much.
    ps0303's Avatar
    Jul 2011
    FL
    3,693
    Is that price for another Raypak/Rheem?
    Paul
    Jun 2013
    Dallas, TX
    105
    Yea, he gave me two prices for a new Raypak/Rheem unit:
    $2,800 new and installed: 399 BTU natural gas, elec ignition (what I have now)
    $2,400 new and installed: 260 BTU natural gas, elec ignition
    I would probably go with the 260 btu since we've only ever used it to heat our spa. Either way, won't be doing this for a while. Too many other priorities.
