Results 1 to 13 of 13
Thread: Does an Intelliflo VS Pump need a GFI??
    Nov 2014
    Palm Desert
    4
    In reading the string, maybe someone can assist.
    My new Pentair Variable speed pump is wired direct and the county inspector requires a GFCI breaker. There is no neutral wire on the pump buss, just 2 hot leads and a ground lug next to it. the manufacturer has been no help, any suggestions?
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Does an Intelliflo VS Pump need a GFI??
    Gfi is required by code.
    Breakers are not cheap nor readily available.
    Neutral is not required from pump to breaker just make sure neutral on breaker is landed on neutral bar in load center.
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    Support the site
    Nov 2014
    Palm Desert
    4
    Pentair Variable Speed Pump GFCI breaker
    My new install has a 3 HP 220v Pentair variable speed pump and the county inspector asks that a GFCI breaker be installed. The connection buss on the pump is marked L1 and L2 with a hot lead to both and the green ground lead to the ground lug. There is no white common lead or an indicated connection but a simple thing to pull another wire from the panel. The factory manual does not address GFCI and the corporate support is no help. Where do i connect the neutral wire no the pump so the Breaker can be installed?
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Re: Pentair Variable Speed Pump GFCI breaker
    no need for the neutral. just make sure to wire the neutral from the breaker to the neutral bar in the panel.
    +1 for what dumbcluck said. Neutral does not get connected to the pump.
    Nov 2014
    Palm Desert
    4
    Thanks. What then needs to connect to the neutral lug on the breaker?
    Mar 2011
    441
    On most 240V loads nothing.
    That lug is for items that need a neutral ( for controls etc).
    20X40 30,000 gallon gunite pool
    The gfci breaker has a white neutral that gets connected in the breaker box. See the picture in the link I posted the the Pentair gfci breaker.
    Support the site
    Mar 2011
    441
    Quote Originally Posted by JamesW View Post
    Yes, but the outlet lug on the GFCI will have nothing attached to it.
    Quote Originally Posted by racket View Post
    The gfci breaker has two connections for the two 120 volt lines going to the pump. The white neutral connects to the neutral bar in the panel.
    What is the outlet lug?
    Support the site
    Nov 2014
    Palm Desert
    4
    you guys are the best. connected as instructed and all is well. Thanks
    Support the site
