Results 1 to 7 of 7
Thread: hayward sand filter pipe leak
    so i've installed a hayward sand filter with unions, but i have leaks. Please look at the photo below. In the photo, there is a plastic part that you screw in, am i supposed to glue the plastic part in or is tightening it by hand enough?
    http://tinypic.com/r/w6tfg9/8
    Mar 2012
    Cincinnati
    33
    Re: hayward sand filter pipe leak
    Teflon tape and silicone will do the trick do not glue
    New Brunswick Canada
    819
    Teflon the threads on the union, 5 complete turns, then make sure the union has an o ring on it. Its the o ring that seals, hand tighten, then 1 1/4 turns more with a wrench.
    thanks for the replies, appreciated.
    30,432
    Generally, that will probably be too tight. 3 wraps is usually adequate and more importantly, I would NEVER tighten a threaded joint much past about 1/2 turn more than hand tight. 1 and 1/4 complete revolutions should not be necessary,,,,,try the 1/2 turn before you go further.
    the threaded joint that i'm trying to tighten into each of the 3 outlets in the multiport valve, the threaded joint has its own o ring on each of the three threaded joints?
    I've put an o ring (was supplied in pack) on each of the threaded joints, the oring sits on the side of the thread that's not visible once 'screwed in.'
