Results 1 to 8 of 8
Thread: Help Identify this Pump housing
    My pump housing is cracked and leaking in air causing a serious lack of water pressure and water returning back into the pool. Of course, the labels are missing or severely deteriorated. Any assistance would be appreciated. The 2 speed pump is still working fine. This is the first time I've ever serviced a pump. Are the dimensions of the motor mounts and water inlet pipes standardized? I seriously doubt it.
    I would like to just buy a replacement housing, but I am prepared to bite the bullet and purchase a new pump and housing combo to get it running again.
    The pump looks like it is a 1081 Pool pump from AO Smith, but the part number is gone. The housing looks like a Hayward SuperPumpII housing based on photo research, but I'm not sure.
    25k gal in-ground, quartz plaster gunite, 400k BTU Heater, Hayward Cartridge Filter w/ Nature2 mineral, Ozone generator, inline 3" puck chlorinator that sucks.
    Re: Help Identify this Pump housing
    I think that it's a Hayward Super II.
    Support the site
    I have noticed that i can buy all of the individual parts to the Hayward Super II, but can't find a place that sells me EVERYTHING but the pump. I don't want to bother with disassembling the housing and figuring out which internal part is worn out. I just want everything but the motor.
    I don't care if I get a new housing and all internals that isn't a Hayward Super II. I just need the existing motor to mate up with the new set up. The FR number is missing digits on the label!!! I guess there are only a few different frame sizes?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Frame size of the motor is a 56J. But my guess is that the parts will end up costing you much more than a new pump. But you said the 2 speed pump is working fine. Did you mean the motor or do you have a second pump?
    If you don't have a spa or any high flow rate requirements, you might be better with a smaller pump. The 1 HP 2 Speed SuperFlo is a good two speed pump at a reasonable price.
    http://www.amazon.com/Pentair-SF-N2-...perFlo+2+speed
    Mark
    The motor is running fine. (sorry for the confusion) Pump/impellers/diffuser/o-rings/etc are all original and may need replacing. I found a few sites that have diagrams for the Super II and individual parts to "add to cart". Total cost was $368 w/o shipping. (ouch)
    mas985's Avatar
    Pleasanton, CA
    11,737
    I would go for a new pump. The SuperFlo will save energy even on high speed.
    Mark
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Unlike spa pumps, inground pool pumps do not offer assembled whole wet end replacements. If 2/3 or more of the wet end needs to be replaced then just get a whole new pump. it will save you long term and eventually those remaining parts not replaced now, will fail eventually. Sooner rather than later.
    Get the whole pump (w/ warranty) and enjoy easy sailing for awhile..... hopefully lol
    I've decided to take the advice and get a whole new pump/motor set up. I'm going to stick with the SuperPumpII footprint. If the new motor dies, I have a "spare" from the old set up. No sense throwing away a perfectly working motor. The new set up is only $40 bucks more than adding everything to a shopping cart for just the "wet end".
