Thread: FC test
    Apr 2013
    Phoenix,AZ
    39
    FC test
    I have a quick question regarding my FC test with the TF 100 test kit. I watched the video recently on how to do the FC test with the TF 100 test kit and it says to fill to 10 mm line. I have been filling to the 25 mm and doing the test accordingly when I do my FC tests. It seems it might be a little more precise to fill to the 25mm line but I could be wrong. What is the consensus regarding this? By the way I have been using the TFP method since the middle of Sept. and appreciate all the info this site has provided along with answers given in the forums. Our pool looks great. Thanks again
    Phoenix, AZ USA 12k gal, IG pebble, Pentair TR-100 sand filter, Jandy/Zodiac ePump series-variable speed, builit 1991 (re-plastered with pebble 2013-new pump 2011), Taylor 2006 test kit with (FAS-DPD) chlorine test w/speedstir, Spa attached
    38,295
    Re: FC test
    With 25ml, each drop is 0.2ppm while with 10ml, each drop is 0.5ppm. There is no need to be more precise than 0.5ppm, so save your reagent.
    Apr 2013
    Phoenix,AZ
    39
    Re: FC test
    Thanks for the info.....as the thing is to save money and reagent replacement can add up.
