Thread: Not round????
    Not round????
    I just installed a 24' round pool. Everything was level within an inch and round. As I was laying the bed of sand, the rails came off in some spots and may have thrown it off from a perfect circle - one rail became bent. I did not notice any problem until the pool filled with water up to around 6 inches from the bottom of the skimmer. One of the posts leans in and the next one leans out . Both are about a 1/2 inch from being level top to bottom. There is also a noticible bulge in the wall where it is not perfectly round. Would continuing to fill with water help and/or What else can I do? Thanks
    Jul 2008
    Pittsburgh, PA
    Re: Not round????
    You need to redo that. Your margin of error is way too loose, you need to shoot for perfect with your block level. 1 inch out will really mess things up and cause what you listed to happen. Sounds like a dangerous situation. I have seen plenty of aboveground pools that look like that standing, but I have also seen a few with blown out walls.
    Involved in the pool and spa industry
    Pittsburgh, PA
