Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: New to TFP - New construction in CFL by Artesian Pools
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Hey all,
    We are in the progress of putting in a new pool after being in our house for 12 years now. The construction process is interesting, but a bit stressful. Feel free to follow along our time-lapse of the process:
    https://www.youtube.com/channel/UCNR...cy4PUPBrfhIYEg
    We'd love to hear suggestions...
    Specs:
    Builder: Artesian Pools
    Type: Gunite
    Size: 29' x 21' free-form w/ spa
    Heater: 300k BTU (LP)
    Control: iAquaLink
    Interior: Stonescapes Tropics Blue
    Deck and coping: Travertine
    Lighting: Pentair LED Glo-Brite
    New Brunswick Canada
    819
    Re: New to TFP - New construction in CFL by Artesian Pools
    Welcome to TFP!
    We always love to see new projects and how people design their pools/backyards/oasis.
    This is the one place that can help you learn to "own" your pool and its water and in turn save a fortune on unneeded chemicals that pool stores love to sell.
    Aug 2014
    Northern IL
    4,615
    Wow. One guy, huh?
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Thanks for the welcome guys! Yeah, I'm not thrilled with the speed of the progress, but I guess having one guy does help with accountability (they are different subs and different guys, just generally one per job). This company has been doing pools for 39 years...so it's hard to argue the construction process with them. I am just hoping to be done by Christmas (the original goal was Halloween and has come and gone....). Question for you guys. The gunite still have a 7-foot 3-inch deep hole in the floor of the pool where rainwater washed it away. Is that "normal"? Or I guess a better question is...should I be concerned? I have pictures if that will help.
    Also, should I be concerned if the tile grout doesn't go all the way down to the shell?
    JB
    819
    No experience with Gunite, but I think it can just be filled in?
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Pictures always help. Welcome to TFP!
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Here are some pictures:
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    As long as there isn't any rebar showing rust it should be able to just be filled in. If its rusted they will have to clean it first but then should be able to just fill it in.
    On another note, what music is that playing with your time lapse videos. It is very calming.
    18x34 Doughboy AGP 22300K Gallons - Build Thread
    Aquaview 24" Sand Filter - 1.5 HP Powerline Pump - Barracuda Ranger - Taylor K-2006 - BBB
    Pool School and Pool Calculator
    Apr 2014
    NE Texas
    327
    I'm by no means at all an expert on gunite, as I'm practically in the same boat as you. However, I'm very surprised at that hole in the gunite. I'm shocked that rain water could do that. If I can recall, our gunite was hardened up enough so you could walk on it within an hour I bet after it was shot. Was it raining when they shot it?
    That last picture looks like a hole they might have left on purpose for hydrostatic relief, but that long one I'm not sure about.
    I bet it's a fairly easy fix, but I would hope it wasn't an indication of improper gunite mix? Don't read too much into this, as I'm virtually clueless...just guessing.
    Done! Pool build thread here
    38 x 18 free form, IG gunite with all gunite waterfall/slide/grotto
    18" raised spa, waterfall into pool
    Hayward 3hp Tri Star Pump x 3, 525sqft Swimclear filter, Polaris 280 cleaner
    Hayward LED pool lights, Hayward LED accent lights, 400K BTU Heater
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    The strength of your shell is derived, in large part, from the steel matrix embedded in the gunite. All the holes and fissures can be fixed right before the plaster goes in. They will put in some quick-cure cement and then apply the plaster. While it doesn't look very appealing, you should have nothing to worry about. The final product will look and function perfectly.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Sep 2013
    810
    Can't tell if it's a leaf or a piece of rebar in the groove at the top of that first picture.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    It depends on which video. All of it is royalty free. Which specific video are you referring to? I think I'm up to seven or eight of them.
    Quote Originally Posted by Glock View Post
    Yes, it rained all night starting about an hour after the gunite was shot. They covered it with a tarp, but given the amount of rain, the tarp couldn't hold it. And you are right...they explained the large hole in the bottom is a "weep hole" give we have a high water level and they didn't want to risk the shell popping out. Fairly normal in FL I guess.
    Quote Originally Posted by Twolabs View Post
    Quote Originally Posted by zethacat View Post
    It's a leaf. I also have a poor dead frog in the bottom since it rained again last night and there is about a foot of water back in the pool. Gotta love FL weather! Thanks everyone for the reply. Talking through these things is helping mine and the Mrs. stress greatly!
    Sep 2013
    810
    Is your pool builder going to warranty the gunite shell?
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Quote Originally Posted by ITR View Post
    Tile day 1 & 2.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Tile day 1 & 2.
    Tile Day 1 is Accralate and Tile Day 2 is Canon in D Major (both by Kevin MacLeod). BTW, love the handle. G19 and G22 lover myself!
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    A few updated videos...the latest one is: http://youtu.be/mXqBJyiq2iA
    Glock's Avatar
    Jun 2012
    Mesquite, Texas
    866
    Thanks. I am a dealer so I let a few hang around in my safe when they come in. I'll list the models just incase the admins take down the image. From 12 o'clock going clockwise: Gen3 G22 RTF2, Gen3 G23, Gen4 G20, Gen3 G19, Gen4 G17, Gen4 G26, Gen3 G21, Gen4 G19.
    Wow, the decking and coping are really nice. Love the time lapse videos.
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Hey guys...I am back. They did the interior today. Is this blotchiness normal and will it even out with brushing as suggested in pool school?
    Sep 2013
    810
    Wow very nice! Is the pool not filling yet? Your PB may do an acid wash or startup.
  20. Back To Top    #20
    ITR's Avatar
    Nov 2014
    Clermont, FL
    320
    Water starts filling tomorrow and goes through Thursday. PB's Pool School is a week from this Friday. I believe they do an acid wash and leave the brush for me to do daily.
