Results 1 to 7 of 7
Thread: Just getting started
    Nov 2014
    Cental Florida
    3
    Ive been following the forums for a while, got a TF-100. You know the drill
    My pool is decently clear, ive used pucks for a while, but now i use cal hypo for about 6 months and it works great. My Pump leaks but were fixing that. The jets seem to run a little slow and the pool dosent look all that blue
    My numbers
    Ph-8.0
    Chlorine-6
    TA-100
    CH-250
    CYA-25
    i have essentially no pool supplies besides my Powder Power Plus, Phosfree(dont use often) some 1 inch Trichlor pucks, and some Baking soda
    10K gallon
    Hayward Super pump-Cartridge
    Nature 2
    Chlorinating method-Cal Hypo/Bleach
    New Brunswick Canada
    819
    Re: Just getting started
    Welcome to TFP!
    You know pucks are bad and using cal hypo for an extended time can drive up Ch.
    That being said, your Ph is high and needs to be brought down. Your reduced flow from jets points to your filter/cartridge needing to be cleaned. Once that is done, you should confirm that your pool can pass OCLT.
    Oct 2013
    Chapin, SC
    1,141
    Welcome to tfp. You're off to a good start with that tf-100 test kit. We normally post fc/cc results. No need to ever use phosfree if you keep your FC at an appropriate level. You might reconsider using calhypo for chlorine. There are detrimental factors for all forms of solid chlorine --calhypo adds calcium hardness which need to be controlled if excessive. You should think about using liquid Chlorine i.e. regular chlorine bleach is often the most cost effective. Also, you may want to increase you cya to 30-50. Your pH is a little high.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Nov 2014
    Cental Florida
    3
    I have no CC, and i cleaned my filter my PSI is now 10, but it still seems a lil slow
    10K gallon
    Nature 2
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    Quote Originally Posted by pooladdict View Post
    Welcome to TFP!
    Pucks are not inherently evil. Being ill informed of how their chemical makeup effects your pool chemistry can help keep a halo on them.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It is not our mantra or belief that pucks are bad. Sometimes, we suggest their use in certain circumstances. One example would be using them in your pool while on holiday.
    As with everything we teach here, the most important element is understanding what we put in our pools, why, and what the outcomes of those additions are.
    Essential Links:
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Welcome to TFP!
    What is "decently clear"? Can you put up a picture?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
