Results 1 to 9 of 9
Thread: How to do a big rise in TA
    Jul 2011
    Austin, TX
    61
    ive just completed a Jacks copper removal program and I've been slowly bringing the water back in balance. Here are today's measurements:
    TC 3
    pH 7.3
    TA 20
    Borates 40
    CH 400 (same as source)
    Temp 68
    CA 40
    Pool math suggests 9# of baking soda to get me to 60. That's a lot! Any suggestions on adding that much? Small batches of 1-2# with checks? All at once? Can I expect some temporary cloudiness?
    Once TA is ins check, I'll work on CA.
    Thanks
    16,000g in-ground plaster pool, attached spa, BBB, DE Filter, SWG
    New Brunswick Canada
    819
    Re: How to do a big rise in TA
    Anytime you are adding that much, its always recommended to add in 3 doses with 8 hours in between. You can then check between. Cloudiness shouldn't occur if you do it slowly, but your Ch is considered high, so maybe go even slower.
    I should mention, it's me that recommends splitting up dosing, not TFP.
    Jul 2011
    Austin, TX
    61
    Quote Originally Posted by pooladdict View Post
    Thanks. Ill take that approach.
    30,432
    I doubt it will be an issue. Some years ago I added somewhere around 20 lbs without incident.
    Caution is the best help, however.
    I had absolutely no cloudiness and it dissolved very quickly and I got valid test results within an hour
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    I've put 10 lbs. of baking soda at once in my 13,500 gallon pool with ZERO cloudiness with pump running in front of a return.
    Jul 2011
    Austin, TX
    61
    I just put another 2# in. I'm at 40.
    I love it when a plan comes together! Thanks for the quick help!
    Oct 2013
    Chapin, SC
    1,141
    When I was needing to add TA, I bought 13lb bags of it at Sam's. I'd use a 16 oz plastic cup and broadcast 3 cups into the pool at a time. Test it again and add more as needed. It too dissolved very quickly.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    mas985's Avatar
    Pleasanton, CA
    11,743
    CSI is not that low now. If it were me, I would leave TA at 40 and maybe raise PH a little with some borax or aeration. With high CH fill water (and high TA too?), it won't be long before you wish you had a low TA. Just speaking from my own experience.
    Mark
    Jul 2011
    Austin, TX
    61
    I agree with keeping it low. I keep it at 50-60 because I dose acid regularly to combat pH drift from SWG and that has a TA erosion effect. No higher than 60 for me.
    Everything's lookin great. TA at 50 and I'm about to swap out acid in doser with bleach for the winter. SWG won't be effective after this week's cold weather. And with SWG off, pH tends to hang tight.
