Thread: RV antifreeze
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    RV antifreeze
    I am assuming that RV antifreeze will not attack the seals in a pool pump, since it is supposed to be used in potable water systems. I plan on draining my pump and filling it with antifreeze.
    Will this be OK over winter?
    New Brunswick Canada
    819
    Re: RV antifreeze
    It's pretty standard to put antifreeze in pumps over winter. Yes it helps protect the seals. Recommend to bring anything that can be brought in, to be brought inside.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: RV antifreeze
    I've only had the Intex pumps before this year, so I wasn't sure. My first time closing with a real pool pump.
    Thanks for the response!
