Thread: TF 1000 Kits for Chlorine
    Stackbarrel
    Guest
    Hi Y'all!
    New to the place and been looking around a while now. I'm curious if one of Y'alls test kits talked about here can be used on my pool. I have mine hooked up with Chlorine Gas, and wondered if the TF1000 kits can test for it? My pool service doesn't know about it, and never heard of it. Thanks for any help y'all, this is a great place to read about pools!
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: TF 1000 Kits for Chlorine
    Yes. The TF-100 will measure chlorine no matter what the source. It is the same as the Taylor K-2006, just bulk packaged to get more reagents for less money.
    On a side note, how do you come across chlorine gas? I've heard of some pool companies using it down south, but never a private pool owner. Is this a public pool? I ask because I'm in KY, and I'm pretty sure no-one within 500 miles has a clue about using chlorine gas for a pool. I work at a plant that makes chlorine is why I ask how you get it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Stackbarrel
    Guest
    Hey, Thanks, for the info. I don't know, I just had it done cause they said it was the best in my large size pool. The company has a special licence I thik is how they do it.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Do they just come and blast it every so often, or do they have a cylinder that is left there with a rotometer to slowly put it in the pool?
