Results 1 to 7 of 7
Thread: SWG for ~20,000 pool, also max temp?
    Oct 2014
    Bay Area, California
    146
    I am thinking of converting my new pool to salt water.
    I've been looking at the Hayward AR9 system, which is listed at 25,000 gallons. How is this measured? With the pump running a certain number of hours per day? Ideally I would only be running the pump while the solar system would be effective. The AR15 system which is quoted for 40,000 gallons is only like 100 bucks more
    Also is there a temperature when SWG's become ineffective? Sometimes I'd like to be able to heat the pool to a comfortable night temperature, meaning 90 or higher degrees.
    New Brunswick Canada
    819
    Re: SWG for ~20,000 pool, also max temp?
    Firstly how big is your pool, we recommend here that minimum is twice the size of your pool, that allows you to run swg and pump on a timer. AR9 only puts out .9 lb cl2 a day...ar15 puts out 1.4 lb a day
    Oct 2014
    146
    Pool is about 20,000 gallons, I was half way through saying that in the title haha.
    819
    Then you want the T15 cell.
    Jun 2011
    Long Beach, CA
    2,790
    The high temperature will not be the problem, SWG's will not produce chlorine when the water temperature drops too low, around 50 degrees or so.
    mas985's Avatar
    Pleasanton, CA
    11,743
    Given we are in the same area and have the same pool size, with a T-15 cell I can get my run time down to about 4 hours at 90-95% SWG setting and consistently maintain a 4 ppm FC level (80 ppm CYA) during the summer (peak load).
    As for heat, higher water temps tend to increase the FC consumption so you might need to set the SWG a little higher.
    Mark
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    That 20,00 gallon pool rating is based on it running 24/7 set at 100%. That's why its for pools "up to 20,000 gallon".
    Always buy the larger cell, it's only about $50 more and will last much longer. It can be set all the way down to 5% if needed or set to run only a couple hours a day.
    chiefwej
