Results 1 to 9 of 9
Thread: Post Halloween Weirdness
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I have an auto cover on my rectangular pool. I use a Little Giant cover pump positioned towards the shallow end of the pool (because that's where my closest power outlet is) and I run a hose to the other end of the pool where I leave the cover open an inch for the hose to drop down a foot into the pool.
    I've used this same setup for 2 years without any problems, other than a float repair. Yesterday morning I looked out to the pool and noticed the pump was moved off position and the hose was pulled back to near the pump. Never seen that before. The pool is surrounded by a high fence with lots of delicate bamboo details that would certainly break if someone tried to climb over it. The gate is locked. I looked for evidence of an animal doing this but there were no footprints or tears on the cover. I thought it might be something like the pool cleaner coming on but I took all the timer triggers off the pump timer last week so there's nothing to trigger the pump on and as far as I can tell it hasn't run since I did this. I checked with some earthquake reporting sites and there's nothing that corresponds there.
    This morning, for the second day in a row it happened again and this time the Little Giant had moved to be completely against the back wall of the pool and the hose had moved with it. The hose is about 25 foot long and kinda heavy.
    Any ideas? Fresh water sharks? Bored squirrels? Ghosts of pool cover pumps past?
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Post Halloween Weirdness
    That is odd. Hard to say if you don't have any critter or people evidence. Solar flares? Heavy rain could perhaps float the hose and move it around on top of the cover but it would be hard for the pump to move without help.
    Isolated Spa - 345 Gallons
    New Brunswick Canada
    819
    Whatever it is, animal or human, train the freaking thing to vacuum your pool
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Haha. Probably be easier than getting the 16 year old to do it!
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    After a break of one day, it happened again last night. Here's photo's of before and after. It seems really odd that the power cord moved up onto the ledge further forward. Again no signs of any animals.
    819
    Ok, that just calls for a trail cam to be installed....has to be a racoon or something like that....weird to say the least
    Sep 2014
    Bakersfield, CA
    155
    My money is on the 16 year old.
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
    Jul 2012
    New Mexico
    66
    Didn't one of the Paranormal Activity movies have a possessed pool cleaner? Yikes.
    Having four boys between the ages of 8-16, that is where money is as well!
    J.
    In New Mexico 20'x36'/3.5' to 8.5'/32,000 gallon/IG gunite/plaster
    Pentair WFE-4 pump/Pentair CC420 cartridge filter/Raypak 266A heater
    2 Pentair Intellibrite LED's/6 Aqua arches
    Coverpools cover with hidden lid
    1,500 sq ft stamped concrete deck
    Polaris robot
    TF100
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I'll have to check if what I think is an epoxy joint between his butt and the computer chair has separated!
