Thread: Pipe to install cover help?
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    I need to put my cover on and found the homeowners did not leave a pipe to stretch the springs. Looking at local pool supply stores none of them carry one. Are they a standard size? Anyone know what size pipe I need to buy, I can stop at lowes on the way home? Thanks!
    In ground (installed 2000), fiberglass, cartridge filter, Pentair Super Flo Single speed pump (2014).
    New Brunswick Canada
    819
    Re: Pipe to install cover help?
    You will want a 1/2" pipe that is solid enough to withstand bending. This pipe then needs to be cut at the bottom so you can twist the pipe free when the spring is in place. This cut also helps big time for removal in spring time.
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    Thanks pooladdict! What do you mean by "cut" at the end?
    Thanks!
    Dec 2009
    Central Massachusetts
    2,690
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Aleforge's Avatar
    May 2014
    Wentzville, MO
    149
    Thanks BK!
