Thread: Air pillows moved
    Jul 2014
    Hudson Ohio
    142
    Air pillows moved
    Ok so the pool is closed and has been for several weeks. Today I noticed the air pillow is all the way to one side. What's the nest way to get OT back to center??
    24'x54" AGP 13,500g AquaLeader Sentinelle | Hayward Voyager CC150 sqft cartridge filter | Hayward 2hp 2spd pump | Hayward Aquaray Cleaner
    Jun 2013
    East TN
    309
    Re: Air pillows moved
    I just loosen the cover cable and pull it back over to the middle. We have a rope tied on both ends of the pillow with some slack. If you dont then you can loosen the cable, get the pillow then tie rope on both ends, then snake one rope under the cover back over to the other side and then pull the pillow to the middle. Tie off your ropes and your done.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
