Thread: Leaking from the waterfall return?
    Nov 2014
    CA
    25
    Hi All,
    I just bought a house with a pool. unfortunately, the pool is leaking.
    I had a leak detection company onsite, and they found nothing.
    Then I was instructed to take off the lid of the waterfall pump, and monitor the water line to see if the leaking stops.
    Because they suspect it's the waterfall return which is leaking.
    However, I don't understand how can that be possible, as the waterfall pump has been always off since I moved in.
    Did I miss anything?
    Thanks a lot,
    Newpoo
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Leaking from the waterfall return?
    Welcome to the forum newpoo
    Don't have an answer for your question but hopefully someone will be along to help you out.
    Photos of the set up might be helpful. How the pump gets water and how the water gets back to the pool.
    Solar Blanket, Well Water, Borax Added. 68
    Apr 2013
    Sacramento, CA
    2,769
    Pictures would really help here. We are rather lost without them.
    Nov 2014
    CA
    25
    Thanks kiss4afrog!
    Thanks gwegan!
    Nov 2014
    CA
    25
    It turns out removing the lid of the waterfall pump doesn't stop the leaking.
    After removing the lid in the morning of Nov5, it still lost 1/2 inch water in 10 hours.
    So I guess it should be something wrong with the pool vessel.
    One thing I don't quite understand is that the leaking speed is slowing down. When the pool is full, it lost over one inch per day. After losing the first 3 inches, it slowed down to about roughly 1/4 inch per day. The evaporation has been excluded from these numbers (I had a bucket beside the pool).
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    The slowing could be that the water is getting closer to the leak so there is less water (water pressure) pushing the water wherever it is going .. just a guess.
    Is the pool itself losing water or is this a pond that makes up the waterfall that's going down ??
    Understanding the plumbing set up is half the battle. Pictures would be helpful.
