Question for you all.
I have an existing Pentair Variable Speed Inteliflow VS+ pump that I installed last year. I just bought the Pentair IC-40 SWG system and i'm curious on the power supply center. When I hook this up, the power center will run 24/7 correct? To prevent it from running 24/7 is there a way to tie in the power center to the VS pump so the power center only turns on and produces chlorine when the pump runs? I would imagine by not having the power center run 24/7 it will increase its longevity. If this cannot be done by connecting it to my pump, is there an alternative method I can use to hook it up or is keeping the power center on 24/7 not an issue?
Any feedback is greatly appreciated.
Eric
Eric
