Results 1 to 12 of 12
Thread: Can the SWG Power Center be tied into the pool pump to be activated?
    Mar 2011
    Tempe/AZ
    117
    Question for you all.
    I have an existing Pentair Variable Speed Inteliflow VS+ pump that I installed last year. I just bought the Pentair IC-40 SWG system and i'm curious on the power supply center. When I hook this up, the power center will run 24/7 correct? To prevent it from running 24/7 is there a way to tie in the power center to the VS pump so the power center only turns on and produces chlorine when the pump runs? I would imagine by not having the power center run 24/7 it will increase its longevity. If this cannot be done by connecting it to my pump, is there an alternative method I can use to hook it up or is keeping the power center on 24/7 not an issue?
    Any feedback is greatly appreciated.
    Eric
    28,000 gallon IG, Plaster Interior
    Hayward Sand Filter
    Pentair Inteliflow VS Pump 3HP
    20+ Years old and use TF Test Kit
    *Pool remodel coming 10/01/14 details to be in new thread
    38,516
    Re: Can the SWG Power Center be tied into the pool pump to be activated?
    There is something called a current sensing relay that can sense when your pump is running and only then provide power to the SWG. It is not recommended to only rely on the flow sensor to stop the SWG generation.
    Another less ideal solution would be to put the SWG on a external timer that you only have on when the pump is running its schedule. The concern being that the timers could get out of sync.
    Mar 2011
    Tempe/AZ
    117
    Is the current sensing relay something additional I need to purchase or is that part of the pump? If it is something I need to buy separate, do you know who in PHX might carry the item so I can go pick it up before he comes out tomorrow to install the power center?
    I have an old pneumatic timer and the guy that is going to be installing my SWG power center recommended we connect it to that. I would rather find a better solution because as you said, they may get out of sync.
    Hayward Sand Filter
    38,516
    It is a separate piece of equipment. Honestly I am not even sure what they look like ... only learned about them on some other threads on the forum.
    Here is a discussion with a few links:
    http://www.troublefreepool.com/threa...tching-for-SWG
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Isn't it posible to just connect the power to the relay that the pump is hooked up to? I have a VS pump, and my AutoPilot swg is hooked up this way...
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Mar 2011
    Tempe/AZ
    117
    Quote Originally Posted by boston62 View Post
    Which relay do you speak of?
    Hayward Sand Filter
    If your pump is switched on and off externally, then you can indeed hook the SWG up to the same power line. However, most variable speed pumps are always powered and are switched on/off either by internal timers or by external low voltage control systems. When using the internal timer approach, the only way to control the SWG is with a current sensing relay. When you have some external low voltage automation system, it generally has the ability to be setup to control the SWG as well.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    The same relay your pump is hooked up to, I just connectef mine to the same pump relay, when the pump turns on so doesn't the swg.
    Autopilot SWG
    38,516
    As Jason said above, it is not common for a high voltage relay to be used with a VS pump. Usually the internal pump timers are used.
    Mar 2011
    Tempe/AZ
    117
    My pump uses the internal timer. So my only option for the pump and swg to sync would be the sensing relay.
    Hayward Sand Filter
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Wow I have been running mine this way, the pump never starts right off when power is to it takes about 30 to 45 sec to start up...I control mine from iaqualink.
    Autopilot SWG
    Sep 2014
    Bakersfield, CA
    155
    Matrix311, check out this thread for info on a current sensing relay:
    http://www.troublefreepool.com/threa...var-speed-pump
    A link to the brand and model number can be found in susa's signature. I've yet to buy one so can't personally tell you if it works.
    Cheers, Peter
    20,000 gal, 52'x17' kidney shaped IG, Pebble Tec, IntelliPro P6E6VS4H-209L pump. Intellichlor IC40 SWG.
    300 sf Sta-Rite System 3 cartridge filter. Poolvergnuegen 4-wheel suction pool cleaner. TF-100 test kit.
