Thread: Aqualink PDA question
    Oct 2007
    Parkland, FL
    752
    My pool decided to start running a little after 11pm last night. I remembered we had a power outage so figured that was the problem. I went to the remote and it was stuck in waiting. After finding the power and killing it to the outside box I finally got connected and reset the time and it seems all is well now. I"m assuming the 9V battery is dead that is supposed to hold the time? Doesn't it give you any warnings about that?
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: Aqualink PDA question
    I don't think so. If the battery is dead, all retained memory is lost when power is cut. Thanks for the tip, I am going to replace mine now.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
