Thread: thanks for the education
    Apr 2008
    long island
    1
    Hi all , I read pool school followed instructions ,the pool calculator is a great tool & article on borates very easy to follow ,well here's my #'s:
    8/1 (adjusted t/a & ph 2 days before)
    FC 8
    CC 0
    TC 8
    PH 7.5
    T/A 80
    CH 170
    CYA 40
    8/2 added borates (borax) 40 ppm as per calculator &shut swg to lower cl, adjusted cya.Turned on swg set at 35% on 8/6 :
    FC 4
    CC 0
    TC 4
    PH 7.6
    TA 80
    CH170
    CYA 60
    From8/4 untill today ph stayed the same it's at 7.8 now ,this is the longest time i didn't have to add acid & have swg on such a low setting .Thanks everyone for all the great info everything went smoothly.
    zeke
    39k roman end L, I/G concrete wall ,viynl liner ,pentair 48 d.e.filter ,2sp,2hp wisperflow pump,2'' plumbing, my blue pool swg & heatpump,blue diamond robot
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Re: thanks for the education
    Glad everything worked out for you! Have fun!!
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Butterfly's Avatar
    South Carolina
    10,045
    Hi zeke and welcome to the forum!
    Congratulations on a job well done!
    You're done SLAMing when:
