Thread: Vinyl vs. Fiberglass
    Oct 2014
    Columbia TN
    2
    We are trying to decide between a vinyl liner pool or a fiberglass pool ...the quotes I have gotten on our area are within a few $100 of each other...what are everyones thoughts please...
    Thank you!
    38,539
    Re: Vinyl vs. Fiberglass
    Welcome to TFP!!!
    There are a lot of discussions about the pros/cons if you search.
    Fiberglass is limited in size and shape. Install requires VERY good prep work. There is no easy way to refurb it. There are a few horror stories of fiberglass installs gone bad.
    Vinyl allows for larger pools and more flexible with shape. Easier to do a DIY install. Easy to replace the liner as needed due to age.
    A lot depends on who is doing the install and what is "normal" in your area. For example. I have never seen an in ground vinyl pool down here and only know of one fiberglass pool ... they are all plaster pools.
    Sep 2009
    Frederick County, MD
    185
    Where I am there seems to be a pretty even split between plaster and liner with fiberglass making some serious inroads. I have only had one pool and it is fiberglass. Despite the size limitations I am not sure I would have gone with anything else.
    Ultimately I think everyone likes what they have and since each has their pros and cons, you have to decide what your needs are.
    Jim
    Southern Frederick County, MD - Leisure Moroccan 38 Fiberglass Pool - 19,800 gallons
    Pentair 1.5 hp 2 speed pump - Cartridge filter - Dolphin robot - TF-100 Test Kit - SWCG
    New Brunswick Canada
    819
    I would think the issue of gel coat problems and tendacy to stain would lead me away from fiberglass. My first choice would be shotcrete, with vinyl coming a close second.
