Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Crisco in gunite pool
    Hey guys! This is my first post 8)
    I have run a pool service and repair business for the last 8 years and have never come across a problem like this. My partner who has been in the business for 30+ years has but he is old school and with all of the advancements lately I thought there had to be an faster way to deal with this than what he advised.
    Here is the story; A bunch of one of my customer's kid's freinds thought it would be wise to use cooking oil to lube the slide sooooo all of the kids coated themselves in crisco and proceeded to enjoy the pool I get the call a couple days later and go out to check it out. Basically I have a film of oil over the top of the pool a nice ring around the tile and a bunch of coagulant on the pool sweep hose. I stuck a finger in and it is sticky like glue. YUCK! Any of you professionals seen this before? Any Ideas on how to handle it?
    I am trying to skim it off the top by running the filter (DE) 24/7 and back washing daily. Just started today but I just know there has to be something out there to hasten the process. Any Ideas???
    Ty
    15x33, 16k gal. vinyl in ground pool
    2008 Hayward 1hp super pump
    Filter: 1995 Purex Triton sand filter
    Re: Crisco in gunite pool
    sorry, no advice, but GROSS!!!
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Casey's Avatar
    SW PA
    10,453
    Suspend pool privledges for all greasy kids
    What a mess!
    Butterfly's Avatar
    South Carolina
    10,045
    Hi kiksroks,
    Welcome to the forum!
    The only thing I could think of to possibly help is a thread from last year..... oops-dropped-paint-brush-in-pool-t2370.html?hilit=%20paint%20brush
    What was your partner's recommendation?
    Please keep us updated on your progress.
    You're done SLAMing when:
    monkeywrench's Avatar
    May 2008
    Shrewsbury MA
    84
    Wow what a mess
    The only thing I can think of to remove the oil slick is maybe try oil boom like they used on oil spills in the ocean. Oil boom is like a cloth tube with oil absorbent material inside. They come about 4 ft in lenght or so under the brand name "pig" . If you have a tax number for your buisness you can pick the boom up a Grainger industrial supply, the do not deal retail. They have facilities all over the country (maybe one near you) or order over the web, takes usually a day for shipping.
    As for being stuck to the walls, have you tried and enzime based cleaner?
    Good luck
    jb
    14x28 IG Vinyl
    12.5k gal
    Hayward SP-Super Pump
    Hayward Pro-Grid 36sqft DE
    Hayward auto chlorine feeder (offline:using BBB)
    Hayward AG Gas heater
    Thanks for the welcome!
    What we have done so far is raise cl. and run filter 24 hours & b/w daily. I'm thinking we will add some clarifier today. It is quite a disgusting mess. How long until I can post pics?
    Round Rock, TX
    529
    You can buy oil absorbing pads that do this for you. They sell them for boating and such. Here is a link, not too expensive either.
    http://www.dawginc.com/spill-control-ab ... l-pads.php
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by kiksroks
    As soon as possible!
    Try PhotoBucket.com
    Mar 2007
    San Rafael, CA USA
    12,082
    Unfortunately, I don't think a high chlorine level is going to help very much because the oils in Crisco are mostly saturated which means they are long-chain hydrocarbons with single bonds. Chlorine doesn't oxidize such chemicals very much. Chlorine does much better with chemicals that have nitrogen or double bonds between the carbon.
    The good news is that the same things that make these chemicals less likely to be oxidized by chlorine make them more likely to stay separated from the water so floating on the surface. This means they can be more easily skimmed off. The equivalent of a very large scum ball could work.
    If you wanted to try and filter these out, then you'd have to run the pump at a high enough speed to form a funnel in the skimmer to pull the surface water into the suction line. However, I'm not so sure a clarifier will help that much to help consolidate these oils since they don't have much separated charges (the molecules may not have polar areas). I think skimming with physical removal from the surface is your best bet.
    Richard
    Oct 2007
    Cedar Hill, TN
    252
    Would the sand have to be replaced? (Like you have to do with baquagoo)
    12500 AGP 2HP Sand filter
    Five years on BBB & loving it!
    Jul 2008
    Arkansas
    20
    This may sound stupid, but could you not use some sort of regular household degreasing spray on a rag and rub the tile? Maybe even with a little baking soda paste for a mild abbrasive? You could lower the water an inch and clean again until the sticky mess was clean. Let me say, I'm NO expert on pools. And obviously you would have to check the water chemistry after the cleaning to deal with whatever has been added. Maybe even close the pool for a day or so just to make sure the chemicals are all filtered?????????
    You know they make those Mr. Clean magic erasers and household ceramic stove cleaners that rub that stuff off too. At least on my stove it does anyway.
    Okay, I'll shut up because know I know my thinking is way to simple to work. But just random thoughts from a simple thinker.
    Ballparkmom
    16 x 33 x 52" AG pool, Hayward Vari-flo pump & sand filter, 1 skimmer, 1 main drain, 1 return, Zodiac LM3 24,000 SWG, Pool Rover Jr., 2 kids & a million toys
    Dec 2007
    Central New York
    504
    Quote Originally Posted by lovingHDTV
    I bought these pads to clean up globs of grease floating in the pool. They work good. To clean the vinyl and the skimmers, I used a kitchen grease cleaner called 409 and lots of shop rags.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    Jul 2008
    144
    The product that you need is called Pool First Aid from Natural Chemistry.
    http://naturalchemistry.com/pool-and-sp ... ts/show/10
    It is made for just this type of thing. The natural enzymes work by breaking down the oils and other contaminants.
    Natural Chemistry also has a product called Pool Perfect that works well to keep things like body oils and suntan lotions from creating scum lines. Pool Perfect is good for cleaning oily waterlines, and in skimmers. It is also good to use while vacuuming during windy conditions. Throw a little bit on the surface of the water and it will create a smooth surface so you can see the bottom.
    Thanks for the help!
    Iv'e ordered some of the pads and one of my ditibuters reccomended and enzyme oil remover. I'll keep you posted
    Guest
    The enzyme will be a big help. It was originally developed to 'digest' oil spills in the ocean.
    This may sound a little crazy but to get the film off the top you can break the surface tension by squirting a little dish soap in the center. The film will then scatter to the sides where it should be easier to skim out.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Mar 2007
    Morris, IL
    477
    Over fill the pool and let it wash out onto the ground.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    Quote Originally Posted by sevver
    I love this one!
    Guest
    Quote Originally Posted by Aquaman95
    You can do the same thing with tile soap and not risk forming bubbles.
  20. Back To Top    #20
    Rockcrawler's Avatar
    El Paso, Texas
    174
    How about using a wet vac and vacuum up the film??
    13,000 IG Plaster, 2hp whisperflo pump, 48 sq in pentair DE Filter, 1 skimmer, 2 eyeball outlets, 200 sq ft solar panels on second story, Auto Pilot SWG-36, Polaris ATV Cleaner
