Thread: Liquid Cyanuric Acid: How long between retests?
    Daf-Tekno's Avatar
    Sep 2014
    Calgary / AB
    70
    Hi TFP,
    When adding liquid cyanuric, how long should be given after adding it until the level can be correctly tested and further liquid cyanuric acid can potentially be added?
    Can it be retested OK after 24 hours?
    Thanks - D
    Jacuzzi J480 (2008) 1700 litres, Balboa ozonator, Delta EZ-18-120 UV lamp via custom 6-way 2-tier timer solenoid array, 2 x Waterway 4HP main pumps,
    1 x Aqua-Flow 1/15 HP circ pump, ChlorMaker IL SWG, SmartSeal + Roxul skirting insulation, 8' x 8' ThermoFloat Spa blanket, 100" x 100" Gator coverall
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I would say after 24 hrs you should be fine to test with the liquid. You might be ok with a couple of hours of circulation. They say it's instant stabilizer but I'd give it sometime to fully incorporate into the water. 😎
    Jeff
    New Brunswick Canada
    819
    Re: Liquid Cyanuric Acid: How long between retests?
    It's also instant wallet lightened, liquid CYA is brutally expensive!
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by pooladdict View Post
    Yes it is. I'll stick with the cheap granular !! 😎
    Jeff
