Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: I've been lurking!!
    Nov 2014
    harrisburg NC
    35
    I've been lurking!!
    my wife has my laptop so I am writing this on an iPad....sorry in advance
    Bought a new house and ran into issue after issue with the backyard pool. I read and googled and read some more. Most of my reading was on this site. Went from an emerald green algae infested pool to ALMOST clear pool. I shocked the heck out of the pool and turned it blue. After cleaning my DE filter I noticed I was putting DE back in the pool. So more reading and googling. After trial and error I decided to buy new filters and vacuuming twice this week, I think I have fixed that issue. I can see that there is a bottom to the pool and it is not white and dusty!
    Without knowing you guys really helped me out A LOT! I suspect I will have a clear pool by next weekend. I thank all of you, some had the same problems I have encountered and others have helped. Without you I probably would have filled it in! Once again thanks for the awesome forum!
    20,000 gallon concrete roman style Inground pool (build date 8/13)
    Pent air FNS60 DE filter (using Jacks filter fiber stuff)
    Raised Spa/Hot tub and Polaris 360 cleaner (named Vincent ;-))
    RayPak pool heater 406a
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've been lurking!!
    Welcome to TFP !
    Glad you found this site and on your your way to fixing the pool up instead of filling it in.
    Sounds like your in the middle of a SLAM. Make sure you follow the directions to the T. If you don't it won't work like it should and you'll have recurring problems.
    The three criteria to stop the slam are
    Crystal clear water.
    CC of 0.5 or less.
    Pass the OCLT Test.
    Going forward how do you plan on chlorinating your pool ? After your done clearing the pool, can you post up a set of test results and what kit you are using so we can see if everything is in line ?
    Any questions you may have don't hesitate to ask. If you can, post up a pic of your pool. 😎
    Jeff
    Nov 2014
    harrisburg NC
    35
    Re: I've been lurking!!
    I have a Aqua Chem (dip,scan,swim) kit
    As of 7 this morning:
    Alk 120
    Ph 7.6
    Free cl 7.5
    Hrd 350
    Cya 115
    All are good but free cl and cya per the test results of this kit. I know it's a crummy kit but I plan on getting a better one, once I figure out which to purchase
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've been lurking!!
    Here is the kit to get. TF 100. Best kit out there IMO and the one I along with most of the people on this site use. It's the best value. I'm not familiar with the kit your using. We base our advice off good accurate testing from one of these recommended kits. Small investment for your pool and keeping your water in balance.
    From looking at those results your CYA is too high and your FC is too low. Can you give us a little history of what you've been adding to your pool so far ?
    Test Kits
    Jeff
    Nov 2014
    harrisburg NC
    35
    TF100 test kit
    Nov 2014
    harrisburg NC
    35
    Where can i find that kit. I saw the chart, best place to buy?
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've been lurking!!
    TFTestkits.net is the place to purchase.
    Here is some more reading if you haven't already.
    ABC'S Of Pool Water Chemistry
    How To Chlorinate Your Pool
    Jeff
    Nov 2014
    harrisburg NC
    35
    I've been watching football and skimming all day. I will continue to do so. I'm learning a lot! Thank you for all the help again. I will order the kit and post the results once I get it. Thanks once again!
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Good job !👍
    Jeff
    Nov 2014
    harrisburg NC
    35
    Like I said in above post, I had DE shooting into the pool, all is well now and now that I fixed the DE issue. I have a semi cloudy pool. It's getting much better everyday. Should I just keep it running? 24/7? Or should I use the timer?
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've been lurking!!
    Run your pump 24/7 until it clears. Having a DE filter will help it clear faster but also the pressure rises quicker. Remember to back wash your filter when the pressure rises 25% above the clean pressure. When you back wash only add 80% of the DE you would add if you did a tear down and cleaned. Some of the DE remains when you just backwash.
    The cloudiness can be from low FC also. That's why we need to know accurately what your CYA level is so we can set the FC range. 😎
    Jeff
    Nov 2014
    harrisburg NC
    35
    Should I run my Polaris vacuum or leave that. My spa is just about perfect so slowly everything is improving. I will upload some pictures soon
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've been lurking!!
    You can run it. Look at my above post. I edit'ed it a bit. Keep your FC up till the kit arrives. Bleach would be best. 😎
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    your Polaris wont help much. It doesnt filter fine enough to remove the cloudiness, and even if it did, it would fill up quick. It just isnt big enough to me of much help.
    Keep your FC and SLAM level and keep filtering 24/7 and you will whip it.
    The TF test kit will help you tremendously.
    Divin Dave,
    Nov 2014
    harrisburg NC
    35
    I just told the wife to grab me some bleach on her way home 20000 gallon pool how much do you suggest?
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've been lurking!!
    That's hard to say. Start with half a dozen. Get yourself familiar with Pool Math if your not. It will tell you how much bleach to add to get to your range. With your CYA level probably being high your looking at water replacement to lower that level. When you get your kit you'll get a better result on that level.
    What do you use to chlorinate your pool now ? 😎
    Jeff
    Nov 2014
    harrisburg NC
    35
    3" tabs right now. I must be real high or my test kit stinks. I vacuumed today and it went below skimmer level, and I refilled it above my normal height
    Raptor 125? Or 350?
    TF100 test kit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I've been lurking!!
    125. It's my sons. He got it when he was eight. He's ten now. Can't keep him off it. It's a nice quad. Five speed with clutch. Re jetted the carb and put a pipe on it. It runs good.
    When we get your CYA level fixed you need to go with liquid chlorine ( bleach ). The tabs are bad news for chlorinating on a continuing basis as they keep raising the CYA level. 😎
    Jeff
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Psigno
    Well, lurking is kind of like sticking your foot in the pool to test the water temp. Lurking lets you learn if you want to join and also gives you some knowledge so you're not starting from scratch on the knowledge curve, it's a good thing
    The chlorinating tablets on the other hand are a bad thing when used all the time as you do get the chlorine (FC) you need and that gets used up quickly but they also add some CYA (stabilizer) with each tablet and CYA doesn't dissipate. Each tablet just keeps adding more and more CYA until it's so high it's causing problems with keeping your pool clean.
    Here are some video how to on testing : https://www.youtube.com/user/tf100te...e=results_main
    Solar Blanket, Well Water, Borax Added. 68
  20. Back To Top    #20
    Nov 2014
    harrisburg NC
    35
    You are correct. I am learning a lot and these few messages have added to my knowledge. I'm going to continue reading. I did not realize the tab was a bad thing as you say above. My FC is low.
    I am a sales mgr for a Powersports store in NC and I know all about the yamaha quads. Great products! He will be itching for more power soon enough!
    TF100 test kit
