Results 1 to 16 of 16
Thread: Excessive Spa Foaming
    May 2013
    Manchester NH
    16
    Looking for some help with excessive foam on my hot tub, thanks in advance
    Marquis 390 gallon hot tub. Outdoor, new england, always covered except when in use.
    We are having excessive foam with air venturis open, no problem when jets on / venturis closed.
    tested water, changed water, added CC to get CH up to 150, tested water, complete water change again!
    Still foaming, and it never used to foam like this. I suspected a kid foam prank, but with the two water changes and the foam level did not get any better or worse, I can't really figure this one out. I am used to the foam gradually increasing over time due to small amounts of detergent in bathing suits, but this is a large amount of foam, from day 1 of the water change to day 30.
    My well has a softener to remove iron and manganese.
    I never had to increase the CH of the hot tub in the past to stop foam, but decided to try it this time, to no avail. I added CC to get the CH up to 150 the last two water changes, both which were done in the past month in order to try to stop the foam issue.
    Here are the current numbers:
    FC 4.0
    CC 0.0
    pH 7.6
    CYA 0-10 - I added 2 tbs of Dichlor so far to this water change, starting 2 days ago. Not much CYA yet.
    TA 70
    CH 150
    I normally use Great Value (Walmart) concentrated bleach (around 8.25%) and only need to use some bleach and do a very small amount of pH balancing over the 2-3 months that the water stays in the tub until the next water change. I have not had to add anything else to the tub in 2 years of using this method until the foam showed up 2 months ago. At that point I tried increasing the CH and then changing the water. Still foaming...
    Any ideas much appreciated!!
    28000 gal inground vinyl installed 7/2013, hayward c5030 525 SF cartridge filter, hayward SP3400VSP variable speed pump, hayward 125000 BTU heat pump, chlorine dispenser
    Re: Excessive Spa Foaming
    Someone almost certainly added some soap, or other surfactant, to the tub. Chlorine will break it down, but it may take several days.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Any chance the bleach you picked up at Walmart is "Splash-less" ?? I know you said "concentrated" but they do have a concentrated splash-less and that stuff would cause your porblem.
    Solar Blanket, Well Water, Borax Added. 68
    Jun 2014
    Houston, Texas
    475
    you know, our spa foams too. We just got it a couple weeks ago. it's not so bad when the pumps are on low but you turn it up and yikes! we're using bromine. My husband tests it and says it's okay. Ofc I have nothing to back that up and show you!
    19k SW IG
    Wet Edge pebble tech = new 5/16 (replaster)
    Hayward variable speed pump (new 6/17) /Shark for cleaning
    New - filled 10/18/14 - TFP 100 test kit
    May 2013
    Manchester NH
    16
    Thinks kiss4frog. The only bleach at Wally world last few trips was "Easy-pour". It is thicker... Is this the problem?
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    DMS2014, what values does he test and what are the numbers ??
    FC
    CC
    pH
    CYA (If outside)
    TA
    CH
    New Brunswick Canada
    819
    Yep, that's the culprit. On one hand though, that foam looks pretty clean, your pipes will be clean as a whistle for winter. I would suggest you drain it, then refill it and rinse and drain again.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I don't know "Easy-pour" but that sure sounds like "Splash-less" with a new name and YES ...... it does foam. Let me check the Wamart web site.
    Or turn everything on (blower too) and see if you can handle all the foam as it will wear off.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Couldn't find it but it sounds like there is something in there that isn't wanted and it's likely whatever makes it thick also makes it foam in pools and hot tubes. In a washer there isn't as much "mixing" going on as running it through a big pump and out return fittings !!
    http://www.troublefreepool.com/threa...t-value-bleach
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Any bleach that is splashless or easy pour will have added surfactants. Surfactants do a great job of increasing the viscosity of a liquid to make it thicker and less likely to splatter and splash. However, these surfactants will also cause lots of foaming. It's a bit like adding both bleach and dishwashing liquid to your pool at the same time with these products. Spa decontamination products such as Ahh-Some contain powerful surfactants to disrupt biofilms and other residues in spa plumbing and can be very useful for decontamination.
    The other source of foaming if it's not a splashless bleach related incident can be low CH levels or organics contamination.
    Isolated Spa - 345 Gallons
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Either draining and refilling or running it enough to use up the ingredient causing the foam are your choices.
    Have you tried using a regular spa anti-foam agent and if so did it do any good ??
    819
    The foam away or antifoam will work, but its adding one more thing to the soup. I actually hated it in my spa, the foaming went away but always left something else in the water.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,772
    That splashless bleach seems to be causing problems everywhere...in pools too. It might warrant its own TFP chapter
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Oct 2014
    Seattle, WA
    47
    You know, before I became a TFP convert, I used to enjoy a good bubble bath at the end of a long week. Sigh.
    3150 gallon (8'x14'x3.75') vinyl lined Original Endless Pool opened 10/10/2014 - chlorine based with UV sanitizer, 50 SF filter cartridge, AG outdoors with opaque retractable cover, Gecko controller In.ex 4 Kw heater, 88 F, triple insulated; Sundance Altamar 390 gallon spa opened July 2000; chlorine based conversion from Baqua Oct 2014; outdoors, on deck, covered, 98F, no ozonator/sanitizer, 125 SF filter cartridge. FAS-DPD chlorine testing.
    May 2013
    Manchester NH
    16
    thanks all. That easy pour bleach was definitely the culprit. 3 water changes and switching back to regular bleach and then 3 weeks of diminishing foam seem to have gotten us back to normal.
    Kiss4, the anti foam did absolutely zero good against these bubbles and I agree I don't like adding it if I don't have to. It went out with the last water change.
    on the bright side yes the spa is quite clean!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You will have to find a new excuse to be groping around now that you can see
