Page 1 of 3 123 LastLast
Results 1 to 20 of 46
Thread: Rebalancing after Jack's Magic #2
    Hi Everyone,
    Need some help. Trying to rebalance my pool after using Jack's Magic #2. It says in the instructions that the FC reading will be skewed for up to 30 days, and to use the CC reading as your guide. I am measuring a CC of 6 and a FC of 1.5 after adding Clorox to help bring up the FC because it has been 3 weeks now with a FC reading of 0.5. Has anyone had this problem, or should I just wait the 30 days and see if it goes back the other way to a correct FC reading and a normal CC reading of 0 which is what I've had. I don't want to over chlorinate if in fact the readings are correct. I use the TF-100 test kit for my testing. Using a SWG. Thanks!
    FC - 1.5
    CC - 6
    Alk - 70
    PH - 7.6
    Cal - 220
    CYA - 60
    18x34 Gunite Pool/Spa with spillover, Jandy LED Lights, Jandy Stealth Pump, Jandy Legacy 400k BTU Natural Gas Heater, Jandy CV340 Cartridge Filter, Aqualink/PDA controls, Polaris 360 Cleaner, Aquapure SWG
    Re: Rebalancing after Jack's Magic #2
    Don't worry about FC being low, concentrate on keeping TC (FC+CC) at the normal FC target level until the full 30 days have passed.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    For anyone else who has no clue what Jack's Magic #2 is : http://www.jacksmagic.com/products/JMCOPPER05.html
    Solar Blanket, Well Water, Borax Added. 68
    Will the FC just adjust back the other way and measure correctly? The CC will go back to the 0 reading i'm used to seeing correct? Thanks for the input, i'll see what happens this week being the 30 days will be expiring.
    Yes, it should go back to normal eventually. If it is fall where you are, the cooler weather may slow it down a bit so it might take a little longer than usual.
    Thanks for the info. I'll keep an eye this week. The 30 days will be expiring.
    Ok, 30 days gone, and still no difference in measurement. I know you mentioned if its fall it may take a bit longer. Any estimates as to when it should go back? My CC measured 8 yesterday and the FC measured 1, which was a bit of an improvement. I've actually turned my SWG way down to get it back to the 3 - 5 that I usually keep it at. Any thoughts on an estimate? Thanks.
    Just got off the phone with a tech from Jack's Magic. He is recommending being the 30 days has expired and my CC is at 7 now I should shock it out. He also wanted to make sure that my PH and ALK was back in balance which it is. Do you agree? Thanks.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    It sounds like it's time to SLAM your pool and get back on a regular diet of FC in relation to your CYA.
    SLAM - - > http://www.troublefreepool.com/conte...tain-shockingl
    After you complete the SLAM by passing the OCLT then you want to maintain a CYA of 70 or 80
    CYA of 70 you would want to target 5ppm FC and a minimum of 3 that you don't want to drop below at any time. http://www.troublefreepool.com/conte...art-slam-shock
    Have you turned your SWG back up to were it had been previously??
    I've turned down the SWG because of the colder weather and seeing the CC climb up continuously. I thought I was getting false CC readings based on the instructions on the Jack's Magic. Now being over 30 days, I'm thinking I agree. It's time to SLAM. Going to the store to get the Clorox! Good news is the water is clear and not green, so I think this will be an easy fix.
    HELP! I started the SLAM process....First got the FC up to 24 as directed by the CYA chart. 1 hour later FC down to 13 and CC had risen up to 15 from 10. Added another 2 1/2 gal of bleach to bring up FC back to 24, and remeasured. CC now at 25!!!??? What is going on? I thought the SLAM level would drop the CC not make it climb. Talked to Jack's Magic tech and he said to wait 24 hours and retest after the second run to get to FC 24. Why is the CC climbing!!!!! HELP, I don't want to over chlorinate if I am in fact still getting false readings from the residual Jack's Magic #2 after 30 days of it circulating. Thanks!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I can't help you with the FC readings, I've never used a stain remover so I don't have any knowledge of how stuff reacts to it. If no one else jumps in with advise I'd go with what the Jack's Magic person said.
    What problem were you having and did it take care of it ??
    It took care of the stains, but the readings are not coming in correctly. I'm just nervous that now my chlorine is now at 50 being you add FC + CC. The water is crystal clear and so it makes no sense. I'll check again tomorrow and hopefully it will start to balance out. If someone else knows whats going on, please HELP! thanks.
    Mar 2007
    San Rafael, CA USA
    12,082
    The MSDS for Jack's Magic Stain Solution #2 (The Copper and Scale Stuff) indicates that decomposition products may be sulfur dioxide and sodium sulfide and that it may also release sulfur trioxide and ammonia if involved in a fire. So the chemical being used contains sulfur and nitrogen, possibly an ammonium compound. That would explain the CC. However, having the CC persist indicates it's not just ammonia. Since I don't know exactly what it is, it may just be slow to oxidize and I suspect that with the water temperature colder that this is the primary reason it is taking longer. Not much you can do about it except wait (or heat the pool, but that seems pretty wasteful).
    Should I continue to SLAM? or do you recommend I let it go and just use FC + CC reading as my FC?
    Mar 2007
    San Rafael, CA USA
    12,082
    Elevated chlorine levels as with a SLAM should in theory oxidize whatever is causing the CC (I hope) so would accelerate the process, but of course that uses more chlorine so it's really up to you which way you want to go.
    Well considering the pool is already at SLAM level, I guess we'll see what happens. Have you ever seen CC go up to 25 like that??? I may also heat the pool this weekend and get the water temp up in the 70's to help the process. By keeping it at SLAM level, it seems the CC is staying or climbing at the same level the FC is. In my mind the chlorine level is at 50 TC which is not good. The Jack's Magic tech also talked about "breakpoint chlorination"....??
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Quote Originally Posted by speeditup View Post
    Well, your Total Chlorine (TC) might be 50 but it isn't a number that should worry you. You need to keep adding chlorine to the pool to keep the FC up to SLAM level (FC/CYA) so that it takes care of the CC and starts to lower it by oxidizing off whatever organic "stuff" you have in there. Just because the water is clear doesn't mean it's clean or that something isn't growing in there.
    You shouldn't use your FC and CC as your FC as it leaves you with very little free chlorine in the pool to do the cleaning. You need to have free chlorine in there to reduce the CC.
    I'm still cautious about you being unsure of the test numbers but with the Jack's stuff past it's 30 days it sounds like either you leave it alone for another week or go ahead and do a SLAM and hope for the best. Even in another week it might still seem the numbers are off. I think you should just slam it with the correct FC for your CYA, try to keep it up there all day for a day or two and see if the CC starts to come down.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I haven't run across "Breakpoint Chlorination". This is what I found on it.
    http://www.in.gov/isdh/files/How_To_Shock_The_Pool.pdf
  20. Back To Top    #20
    We'll see where its at tonight when I get home. I may continue the SLAM for a day or 2 more in hopes of that high CC of 25 to come down.
