Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Closing on a house with badly stained pool
    Oct 2014
    Bay Area, California
    146
    See the picture attached.
    To me the color looks like they are organic but it covers a large portion of the whole pool. The pool does use copper pipes and the owner "maintains" the water himself.
    What do you guys think? Buy jacks stain ID kit?
    I think the pool is pretty old but the plaster appears to be in good shape, besides the staining obviously.
    UPDATE: Ok so they said it wasn't painted. They also said that the neighbor said that the pool was drained and refinished in the 80's, and the pool was originally installed in the 60's!!!
    Mar 2013
    Houston Texas
    90
    Re: Closing on a house with badly stained pool
    I'd get the stain ID kit and see what that is. How big is the pool and do you know how old the plaster is? Does it have a heater?
    45'6" x 19' x 26' gunite pool, 43,000 gallons! 3/25/2013 renovation: Arizona Buckskin flagstone coping, NPT Verona Borba Turquoise tile & deco tile, Jules Bright Blue glass trim tile, Altima Premium Plaster in Teal, Pentair Whisperflow 2.0hp Filter Pump, Pentair 60 sq ft DE Filter with Multiport Valve. Polaris automatic cleaner.
    New Brunswick Canada
    819
    IF it has copper pipes its almost guaranteed metal staining. Drop a Vit C tab on it and it should come white in a very short time. If it is metal, then the copper could be causing the issue and I believe it will continue to cause it if the Ph elevates the slightest.
    Oct 2014
    146
    No heater, used to be some solar panels on the roof (could see in google maps) but they are gone now, guess they started leaking and the owner took them down.
    I think the plaster is more than 10-15 years old but seems to be in good condition besides the stains. If I can get the stains out and make it a couple more seasons that would be great.
    By my estimation the pool is 20,000 gallons or less.
    Quote Originally Posted by pooladdict View Post
    The previous owner has rent back for about 2 months after closing, should I try and deal with it before I move in? I'm guessing it has been this way for a long time.
    819
    I would point out how much work you will have to do to get pool up to par, maybe see how low he can go?
    Oct 2014
    146
    Already done that
    It kind of looks like the pool had been painted and most of the paint has come off. Has the pool ever been painted? Try rubbing your hand on the walls to see if you get white residue on your hand.
    Can you post a full set of chemistry readings?
    What history can you get?
    Support the site
    Oct 2014
    146
    I vigorously rubbed one of the stains on the wall with my hand and I don't remember any white residue on my hand. There was a touch of cloudiness in the water though, in the few inches around where I was rubbing it. Stain didn't budge.
    I will try and get some history. The owners are neglectful idiots
    The whiter areas look like paint. The darker areas look like old stained/dirty plaster where the paint has worn away.
    I would suspect that the pool had been painted a few years ago as an inexpensive alternative to doing a replaster. The water does seem to have a greenish tint that could be from copper.
    Try rubbing the lighter areas to see if white paint comes off on your hand. The cloudiness that you saw previously could have been from paint or from deteriorating plaster.
    If possible, ask the previous owners for a list of everyone they have used to service the pool. Then contact the people/companies to see what they can tell you.
    What equipment does the pool have? Pumps, filter, chlorinator, heater etc.?
    Support the site
    Oct 2014
    146
    The pool owner does the service themselves, and judging by how handy they were with other aspects of the house they suck at it.
    No heater, single speed pump for circulation, separate pump for cleaning robot (which is no where to be found), filter is a old hayward model I think but I dont know the type/condition. I was planning on replacing all that stuff with variable pump and new Hayward Preflex DE filter.
    Oct 2014
    146
    Also there used to be a HUGE tree in the back yard, so organic contamination is possible as well.
    Oct 2014
    146
    Another picture of the staining, and also leaves and dirt sitting on the bottom
    The grey could be copper stains. This picture also looks like the pool was painted.
    Support the site
    Oct 2014
    146
    The really dark area (the grey you are referring to?) is dirt etc.
    Thats going to be a bummer if it was painted but I was prepared to not be able to remedy the problem myself.
    The pattern of the staining does kind of seem to have the design of a rolled on paint, or maybe chemicals poured down the walls?
    Oct 2014
    146
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I'd try the ascorbic acid (Vitamin C) tablets on the stains to test for metal staining. I'd also try putting a trichlor puck on them as well to see if they are organic.
    The pattern to the staining does look a lot like paint lines...
    Looks like it could be a beautiful pool with some TLC. Taking the water to the pool store could get you semi-accurate metals results or you can find a nearby environmental lab to test the water for metals. My local lab charges $45 for a water suitability test including levels for Calcium, Chloride, Copper, Iron, Magnesium, Sodium, Conductivity, Hardness, Nitrate, pH, Sulfate and Dissolved solids. Many labs will test for single metals for about $15 each.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    To my eyes, that looks like stained Calcium from a poor plastering job. The marks are trowel marks. But it's hard to tell from a photo.
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Perhaps it would be worthwhile to get a service person for an onsite diagnosis. It's difficult to see from pictures.
    Even though they say that it wasn't painted, I still think that it looks like paint.
    Support the site
  20. Back To Top    #20
    Oct 2014
    146
    I gave it the rub test, nothing on my hand. The current people have been there since 2001 and never painted it. Is there another type of paint that could have been used prior to that that wouldn't leave a residue? Said when they moved in it looked pretty similar to how it does now. The plaster is visually in great condition, except for the discoloration.
    I will order a stain ID kit
