Results 1 to 9 of 9
Thread: What is the best Heat pump for my 32x16 Intex pool
    Sep 2014
    Dallas
    36
    Hey guys the wife wants a heater for the pool, can you tell me what size and what would be the best one for us to use.
    Yachtnutz
    New Brunswick Canada
    819
    Re: What is the best Heat pump for my 32x16 Intex pool
    Me personally, I would go with solar. 2 to 3 80 sq ft panels and you would get a good jump in temps, best part is, once its paid for, it doesn't cost any extra to run.
    That being said, if you are dead set on a Heat Pump, the first question would have to be what temp do you want your pool at most of the time?
    Sep 2014
    Dallas
    36
    Thanks I'd say around anywhere from 68Degs to around 76Degs max
    Yachtnutz
    819
    50,000 to 80,000 BTU would be fine then. Do some searches on here for recommended brands.
    Sep 2013
    Connecticut
    728
    Quote Originally Posted by yachtnutz View Post
    Yachtnutz
    Just double checking -- you (and your wife, who wants the heater) prefer to swim in water between 68 and 76 degrees? That's a bit chilly by most standards
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    It would be helpful if you added your pools info to your signature as outlined here - - > http://www.troublefreepool.com/conte...etting-started
    I would guess they intended to say 78-86
    Solar Blanket, Well Water, Borax Added. 76°
    Sep 2014
    Dallas
    36
    Sorry I mean 78 -86
    Intex Ultra Frame 32'x16'x52" ,19x35 concrete slab, 1" Extruded Foam Board Insulation,
    Gorilla Floor Padding, ground cloth, LED lighting, Dolphin Supreme M500 Robotic cleaner.
    Krystal Clear™ Sand Filter Pump and Saltwater System with 2,650 gallon per hour flow rate
    Water Capacity (90%): 14,364 Gal, Hayward SP1091WM Dyna-Skimmer Kit.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    My girlfriend is like that. She wants 80s and thinks if it's in the 70s it still has ice in there somewhere
    Orlando, FL
    690
    Our pool was 84 until yesterday but the kids would only swim for a few minutes because the ambient temp was to chilly. I would think that during this time of year, the minimum temp would need to be 80 but that's just me. I have not been in since the pool temp dropped out of the 90s.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
