Thread: Measuring temperatures with Pentair EasyTouch
    Oct 2014
    Clermont, FL
    5
    I see the Pentair EasyTouch pool only system provides three temperature sensor connections; air, water and solar. With the solar sensor used to determine the solar panel roof temperature. I will have a solar system plus a Pentair UltraTemp Heat pump. Is there anyway I can monitor the pool water temp, the solar panel water output temp and the heat pump water output temp?
    I don't see any reason to monitor the air temp except for freeze alerts, which here in central Florida is not very frequent, so I could do that manually so to speak. But I don't see an easy way to monitor the water temp in 3 spots. But maybe I am missing something?
    As far as why, I would just like to know what the contributions of heat sources are to raising the pool temperature at varying times of the day or year. I suspect the heat pump contribution will be small but I'd still like to understand how the overall system is working, just the engineer in me. Sometimes I will be running solar only and sometimes solar + heat pump. And during the summer heat, neither.
    Thanks!
    12K gal, IG, plaster, Jandy CS200 cartridge filter, Pentair 011018 IntelliFlo Variable Pump, solar system. Adding soon - Pentair 125K Ultratemp heat pump, IntelliChlor IC-40 SCG.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Measuring temperatures with Pentair EasyTouch
    The water temp sensor is what monitors the water temp. Once installed, it will tell you what temp your water is and it's also used to determine if your heater needs to turn on based upon your water temp setting in the ET.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Oct 2014
    Clermont, FL
    5
    Yep, thanks. I was looking for a way to monitor the water temperature it multiple locations so I understood how the solar unit and the heat pump were heating and contributing to the overall pool temperature. So I was hoping a could somehow see multiple water temperature readings at different locations.
    Mar 2011
    441
    Quote Originally Posted by Hotairfl View Post
    You could do that with another piece of equipment like a honeywell t775 thermostat, or you could just get 3 of these http://www.sunplay.com/Pentair-Inlin...10330_a_7cSL2D and monitor them.. I don't know of any pool controller that will do what you want to do.
    20X40 30,000 gallon gunite pool
    Feb 2011
    Petaluma, Ca
    665
    Quote Originally Posted by racket View Post
    It would be nice if inline pool thermometers only had a range of 50 / 110 deg, that way you could easily read small variations, why would it ever need to go to 220 deg? Ideally for monitoring your solar it would be an even smaller range.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
