Thread: Spa Jets
    Oct 2014
    Columbus, Ohio
    23
    Spa Jets
    Hello all,
    I've encountered a gunite spa with diamond Brite that was built very poorly. Not only is the shell starting to crack the pressure in all of the return jets is very weak. The spa is very close to his system, I saw pictures of the build the homeowner took and it appears 2" pvc was being used.
    Any idea what is causing this?
    Thanks
    38,295
    Re: Spa Jets
    Welcome to TFP!
    You leave out so many details that any idea would be a guess.
    Pump type and size?
    Filter type and size?
    Filter pressure?
    Number and size of jets?
    Etc.....
