Thread: Fitting for pool return
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I have 4 jets on my IG pool. Eyeball removes easily, just unscrew large "nut" holding it in. Do they make a 1.5" hose adapter that will screw onto the remaining male thread. I plan on adding a Solar Bear collector that I want to push water from the return to the panel and back into pool with another hose. I'd like it a quick change fitting so I can remove the hoses when pool is in use. Maybe something similar to how a pressure cleaner attaches (but with 1.5" hose). My plan is to have most piping hidden except the 2 hoses into the pool. Going to try solar before investing in a heat pump, so this is likely a temporary test.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    New Brunswick Canada
    819
    Re: Fitting for pool return
    Yes you could do it that way, but if the route for the water is harder then the other three returns, it will just diminish the flow to these panels. Water will take the route of least resistance. Remember solar panels are the most effecient when the water flows through them rather quickly.
    It would be easier to run a three way valve after your filter and then plumb in your line to the panel and from panel back into return line to pool.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    You should be able to pick-up a fittings at a big box store like Menards, Homedepot ... but the selection won't be as wide as a pool store or on line. You can order them from a pool parts store on line depending on how you want to plumb it to the solar collector. Depending on if you need to go from the in wall, female 1.5" to a barbed fitting or to a slip fit for flex or rigid tube or go male to male or male to female or even reduce to a garden hose coupling the stuff is out there.
    You can always restrict the other returns with smaller eyeballs to increase the flow in the one you're going to use.
    Solar Blanket, Well Water, Borax Added. 68
    tcat's Avatar
    May 2012
    Austin, TX
    731
    That's what I'm looking for, the "flexible 90". I have the 1 st slotted one on 3 returns and poolskim on the 4th. I was going to connect to a return that use to be the cleaner line, so it's separate and can be controlled at the equipment. Looking for a quick way to switch between solar and the existing slotted eye. I'll look for that 90 online. Thanks!
    DIY chlorine feed
    BBB
