Thread: Fiber optic light leak
    Oct 2014
    Charleston SC
    6
    I've been dealing with an annoying leak lately and the ink test confirmed that the leak was around the lens for the fiber optic light. I am trying to take it apart to find the worn / damaged gasket / oring. I drained the water to below the light and fabricated a tool to unscrew the "lens nut" which looks just like the pentair 22100100 nut found here http://www.poolpartsonline.com/p-970...-lens-nut.aspx The plastic lens nut is cracked in one part but I don't think that's causing any leakage, I'm looking for a gasket or oring and do not see one in there. This diagram http://www.pentairpool.com/pdfs/Fibe...AssemblyIG.pdf shows that if I unscrew the lens there will be an oring in there. I cannot figure out how to unscrew the lens and it doesn't budge with my fingers (it is recessed in the housing). Is there an easy way to do this?
    22,553
    Re: Fiber optic light leak
    If there are no cracks in the housing then it's most likely leaking behind the spacer with O-ring in the diagram linked. The first thing I'd do is replace the lens retaining nut and see if it'll tighten it enough to stop the leak. If that doesn't work you'll need to get enough slack in the fiber bundle and pull the light assembly out of the housing and replace the O-rings. If you're adventurous, you may want to pull the lens out and unscrew it and dry it out a little anyway.
    Mar 2011
    441
    I would replace them with LED products from Jandy, Savi, or hayward. You will like the much higer light output
    20X40 30,000 gallon gunite pool
