Results 1 to 10 of 10
Thread: powdered CYA in the inline chlorinator ?
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    Can I put powdered CYA in the inline chlorinator (I use a stenner pump & liquid chlorine) instead of using the sock method ?
    23k gunite, Stonescapes Mini Aqua Blue w/seashell, Pentair CCP520 cartridge filter, 2 Pentair Intelli-Flo VS pumps, Pentair Mastertemp 400, Pentair EasyTouch 8+wireless controller, Silencer spa blower, 3 Intellibrite LEDs, Pentair Racer cleaner, Pentair 320 chlorinator
    my build http://www.troublefreepool.com/threa...-north-Houston
    New Brunswick Canada
    819
    Re: powdered CYA in the inline chlorinator ?
    I think it would take forever to dissolve, the sock method is the ideal way.
    Adding CYA using an inline chlorinator is dangerous, there is a small explosion risk and the chlorinator will likely become clogged. I also recommend the sock method.
    cnatra's Avatar
    Feb 2014
    Houston TX
    187
    alright , I'll stick with the sock method then
    langerking's Avatar
    Jul 2013
    Clermont, Florida (that's near Disney World)
    104
    I added CYA using the sock method. Had 2 tube socks tied together and hung them over 2 noodles. In the first 24 hours, had very little dissolving going on. Then I took the socks and started massaging them in the skimmer, could see the powder working its way out. Thought to myself, "hmmmmm.... I need to fill the pool some anyway, why not run the hose into the sock for a while. This seemed to work nicely, then I stuck the one sock inside the other so that the water was flowing through both the socks. In an hour, almost all the CYA was flushed out of the socks.
    1) 21,000 gallons
    2) DE
    3) IG (in ground)
    4) Vinyl
    5) Hayward 1.5 hp DE 3600 72 GPM
    Taylor K-2006
    STA-RITE Great White GW9500
    Dec 2012
    Orlando, FL
    28
    The two times I have added CYA I filled and tied the tube socks and just threw them in the deep end and used my brush pole to situate them directly over the main drain. They were empty within 2 hours both times I did this.
    16'x35' Gunite/Marsite Kidney shaped 12500 Gal,Old (read Original) Sta-Rite TXC-75 75sqft Cartridge (Now a Single cartridge replacement, used to be two separate carts one 50sqft and one 25sqft stacked), Built with the house in 1989
    38,548
    Quote Originally Posted by RickyTidwellsMom View Post
    I don't think I am a fan of this idea ... higher risk of damaging the pool surface if not completely on the drain or if flow is insufficient.
    Mar 2007
    San Rafael, CA USA
    12,082
    I use an old T-shirt in the skimmer. This works well though a sock could be used instead. The flow through the skimmer accelerates the dissolving. Just make sure that there are other ways for flow to occur to the pump in case the skimmer gets clogged. In my case, the skimmer has a second input from the pool, a pipe hole below the skimmer (I think it's called an equalizer) and I also have main drains so there is no risk of damage from clogging the skimmer.
    Dec 2012
    Orlando, FL
    28
    Is CYA damaging to the pool surface if left on it? I always make sure the flow is 100% through the main drain when doing so and again, all of the CYA was gone from the sock within 2 hours.
    38,548
    CYA is an acid after all and yes it can damage the pool surface if it sits for long.
