Last time I had this type of issue the thermal regulator was replaced in 2010. Getting a code E01, r=05 and LED light 11 & service light goes on. Pulled the thermistor and tested with a meter and getting 8.5 on resistance/Ohm. Is there anything else I should test or is this a bad thermistor? Not a pro on multimeter testing so any instruction to narrow the source would be appreciated. Also, when I apply any type heat to thermistor while testing the reading goes down.
Problem: The heater stays on for a bit and then turns off, keeps recycling from on and off.
